I Need Advice with Custom Commands Not Responding Properly
Elizashahh
Hello there,
I am encountering an issue with my SinusBot setup and was hoping someone here might be able to help.
I have been working on customizing my SinusBot to include a variety of commands for my server; but I am running into a problem where some of my custom commands are not responding as expected. Specifically; when I try to use these commands, the bot either does not reply at all or provides an incorrect response.
I have double checked my command scripts and configurations to ensure there are no syntax errors; and everything seems to be in order. I also made sure that the commands are correctly defined in the SinusBot web interface.
I have tried restarting the bot and clearing the cache; but the issue persists. I would really appreciate any insights or troubleshooting steps you might suggest. If anyone has experienced similar problems or knows of any common pitfalls that could be causing this, please let me know.
Also; I have gone through this post; https://forum.sinusbot.com/threads/sinusbot-ts3-chat-commands-blue-prism-not-working.7413/ which definitely helped me out a lot.
If there is any specific log file or configuration setting that I should review to diagnose the issue,;please point me in the right direction.
Thank you in advance for your help and assistance.😇
minini
  • follow this steps i think that should help you troubleshoot and resolve the issues with your SinusBot configuration.
  • Vérifiez le script : assurez-vous que la syntaxe de vos commandes personnalisées est correcte. Même une petite erreur peut entraîner des problèmes.
  • Autorisations : vérifiez que le bot dispose des autorisations nécessaires pour exécuter les commandes. Cela inclut les autorisations du serveur et du script.
  • Mise à jour de SinusBot : Assurez-vous d'utiliser la dernière version de SinusBot et de ses scripts. Parfois, les mises à jour corrigent des bugs.
  • Journaux : vérifiez les journaux de SinusBot pour détecter d'éventuelles erreurs ou avertissements liés à vos commandes. Cela peut vous donner des indices précis sur ce qui ne va pas.
  • Assistance communautaire : Si vous rencontrez toujours des problèmes, pensez à publier votre problème sur les forums SinusBot ou sur Discord. La communauté peut souvent fournir des informations et des solutions précieuses.
Jniklas2
Please write in english in this forum
