2017-03-17T23:55:23+01:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-03-17T23:55:22+01:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-03-17T23:55:21+01:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-03-17T23:55:21+01:00 TS |INFO |LicenseViewer | |Found cached license for version 1 and language en
2017-03-17T23:55:21+01:00 TS |INFO |LicenseViewer | |License language: en
2017-03-17T23:55:21+01:00 TS |INFO |Update | |Check license version: 1
2017-03-17T23:55:21+01:00 New connection status 4; Error 0
2017-03-17T23:55:21+01:00 TS |INFO |PermManager | |Loading permissions from cache
2017-03-17T23:55:21+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-03-17T23:55:21+01:00 New connection status 3; Error 0
2017-03-17T23:55:21+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-03-17T23:55:21+01:00 New connection status 2; Error 0
2017-03-17T23:55:21+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-03-17T23:55:21+01:00 TS |INFO |Update | |Checking for updates...
2017-03-17T23:55:21+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 26
2017-03-17T23:55:21+01:00 TS |INFO |ClientUI | |Checking for update
2017-03-17T23:55:21+01:00 TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2017-03-17T23:55:21+01:00 New connection status 1; Error 0
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-03-17T23:55:20+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/20a78e78-39d8-407a-a201-917323e72c50/51cb5f75-9176-4db8-bcaa-34ca0751159b/settings.db
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-03-17T23:55:20+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-03-17T23:55:20+01:00 TS |INFO | | |*** Time [INIT]: 387
2017-03-17T23:55:20+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 386
2017-03-17T23:55:20+01:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2017-03-17T23:55:19+01:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2017-03-17T23:55:19+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-03-17T23:55:19+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-03-17T23:55:19+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-03-17T23:55:19+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-03-17T23:55:19+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-03-17T23:55:19+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-03-17T23:55:19+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
2017-03-17T23:55:19+01:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017-03-17T23:55:19+01:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2017-03-17T23:55:19+01:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2017-03-17T23:55:19+01:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1+deb8u2 (2017-03-07) x86_64 Binary: 64bit
2017-03-17T23:55:19+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-03-17T23:55:19+01:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/20a78e78-39d8-407a-a201-917323e72c50/51cb5f75-9176-4db8-bcaa-34ca0751159b/crashdumps
2017-03-17T23:55:19+01:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/20a78e78-39d8-407a-a201-917323e72c50/51cb5f75-9176-4db8-bcaa-34ca0751159b/crashdumps
2017-03-17T23:55:19+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-03-17T23:55:19+01:00 New channel
2017-03-17T23:55:19+01:00 Could not insert into Notifications-Tableno such table: Notifications
2017-03-17T23:55:19+01:00 Could not delete from Notificationsno such table: Notifications
2017-03-17T23:55:19+01:00 Auto-Playing last track
2017-03-17T23:55:18+01:00 Last track was 43091986-bee2-4007-a1c1-bcdebf32e4dc, will auto-play soon
2017-03-17T23:55:18+01:00 Auto-Starting 20a78e78-39d8-407a-a201-917323e72c50/51cb5f75-9176-4db8-bcaa-34ca0751159b in 500 ms...
2017-03-17T23:55:18+01:00 Initialization complete
