install does not work on debian 11
tatayer
I am trying to install sinusbot docker, but it doesn't work under debian11. is this normal?
Is there an error in the docker image?
cordially
Lala Sabathil
Would you please send additional details like logs, error messages and so on?
We can’t help you without this info
MauriceR
==> Unable to open /tmp/.sinusbot.lock. Is SinusBot already running?
Well, it seems like sinusbot is already running, or wasn't stopped correctly.. Check if there's any running process, if not -> this
tatayer
Problème résolu avec un mix dinstall. Le VPS sous debian 11 et sinusbot sous docker dans 1 container avec debian 10
