Instance settings error
VEERZ
hello...
I used this bot and it was fine and everything worked normally.But now when i try to edit instance settings, all boxes are empty (name of the bot and etc) and when i try to fill the same and save it, it doesn't get saved and now i can even start the bot.it says "Instance not configured properly. Need at least host/ip, port and nickname".Please see below screen shots.
http://s10.postimg.org/svodfnno9/asasas.png
http://s28.postimg.org/o5iki4c0t/ghngn.png
bot log - 2015-07-30T15:14:12+05:30 INSTANCE-DELETE [admin] (c30bd209-cb41-4a7f-80c5-2e767b23f41e) OK
instance log - 2015-07-30T15:14:30+05:30 Starting instance ts3server://?port=9987&nickname=test&password=&channel=&channelpassword=
thank you.have a nice day.
Please try to restart the bot process and wipe your browser-cache. Then reconfigure the instance.
Sounds like you ran into a rare bug that will be fixed with the next release.
VEERZ
Already tried restarting bot process.Now I used internet explorer to log in to the bot panel and worked fine :D.Never thought that I will have to use IE.thanks anyway.hope this will fix in the next release.thank you very much.
Umm :) Please try again using your other browser. I've only tested the bot with IE once, so it's definitely not optimized for it. Development is done entirely with Chrome / Firefox.
I guess it's just the cache or some weird internals. Which browser did you use?
VEERZ
repeatedly pressing F5 didn't solve the issue.cache cleared but still negative.i'm using chrome.
