instance wont spawn
raf
i cannot start instance, this is log:
2016-03-01T02:40:13+01:00 Starting instance ts3server://178.32.79.175?port=9266&nickname=bot1&password=*******&channel=&channelpassword=
2016-03-01T02:40:13+01:00 Error spawning instancefork/exec d:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: The requested operation requires elevation.
2016-03-01T02:40:13+01:00 TSClient quit.
*i changed server password with stars.
GetMeOutOfHere
if i am not wrong, sounds like a security lvl identity problem
Xhavest
i found is was having the same issue on Linux if you have the bot set up on a different user you must have the GUI enabled and be logged into it. otherwise it crashes the TS client when it tries to run. i would also recommend looking at the config.ini file to see if the path to the client is correct.
