Instanz stürzt sofort ab
Professor Varox
Guten Abend,
Ich habe einen VServer gekauft und wollte den Sinus Bot installieren. Es hat auch alles geklappt, aber als ich den Bot starten wollte, kam diese Meldung ins Log:
2019-10-30T21:27:08+01:00 closing channels
2019-10-30T21:27:07+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-10-30T21:27:07+01:00 Closed.
2019-10-30T21:27:07+01:00 TS>
2019-10-30T21:27:07+01:00 TS>Available platform plugins are: xcb.
2019-10-30T21:27:07+01:00 TS>This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
2019-10-30T21:27:07+01:00 TS>qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
2019-10-30T21:27:07+01:00 TS>qt.qpa.xcb: could not connect to display unix/:40.0
2019-10-30T21:27:07+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-10-30T21:27:07+01:00 TS>/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/TeamSpeak3-Client-linux_amd64/libQt5WebEngineCore.so.5)
2019-10-30T21:27:07+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=System1&password=&channel=&channelpassword=
Nach der Ausführung des Scripts:
 - Operating System: Ubuntu 14.04.6 LTS (OpenVZ)
 - Kernel: Linux 2.6.32-openvz-042stab140.1-amd64 x86_64
 - Load Average: 0.00 0.01 0.00
 - Uptime: 0 days, 20 hours, 36 minutes, 26 seconds
 - OS APT Last Update: 30.10.2019 15:45:32 EDT -04:00:00
 - Shell Locale: (not set)
    CPU(s):                8
    CPU MHz:               838.977
    Virtualization:        VT-x
 - RAM:  B/2.00 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 1.97 GB/35.00 GB in use (5%)
   - libglib: 2.40.2-0ubuntu1.1
 - Status: running (PIDs: 22437 22436, User: sinusbot)
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.10.29)
 - Installed scripts: Support.js; advertising.js; alonemode.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; support-channel manager_de.js; welcome.js
    linux-vdso.so.1 =>  (0x00007ffc33f93000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f99131a5000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f9912e4d000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f9912a4c000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f99120e6000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f9911e72000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9911c66000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f991195f000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9911741000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f991143d000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9911226000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9910e5d000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9910c44000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9910a3b000)
    /lib64/ld-linux-x86-64.so.2 (0x000055d3e6461000)
 - Time (local): 30.10.2019 16:25:10 EDT -04:00:00
 - Timezone: America/New_York
 - TeamSpeak3 Version: 3.3.0
 - youtube-dl Version: 2019.10.29
Und kommt bitte nicht mit "Das gab´s schonmal irgendwo" oder verweist auf irgendeinen anderen Thread, ich habe (alle?) Threads zu diesem Problem durchgelesen, aber das Problem ist immer noch das Selbe
