Solved Instanzen starten nicht
wie oben schon gesagt, starten die Instanzen nicht mehr. Hier mal der Log:
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/OrTak:1
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
[dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
2015/09/13 13:11:06 7dc2c93a INFO Initializing bot://7dc2c93a-e612-442e-8830-bf5b718e7d2d
2015/09/13 13:11:06 7dc2c93a 53465aad INFO Loaded
2015/09/13 13:11:06 7dc2c93a 7ccc9296 INFO Loaded
2015/09/13 13:11:06 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/09/13 13:11:06 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/09/13 13:11:06 youtube-dl checking...
2015/09/13 13:11:07 youtube-dl version compatible, support enabled
2015/09/13 13:11:07 RadioStation data loaded
2015/09/13 13:11:07 Imported radio stations
2015/09/13 13:11:17 7dc2c93a 7ccc9296 WARN Could not delete from Profilesno such table: Profiles
2015/09/13 13:11:17 7dc2c93a 7ccc9296 WARN Could not insert into Profiles-Tableno such table: Profiles
2015/09/13 13:11:17 7dc2c93a 7ccc9296 DEBUG Could not delete from Notificationsno such table: Notifications
2015/09/13 13:11:17 7dc2c93a 7ccc9296 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/09/13 13:11:17 7dc2c93a 7ccc9296 DEBUG Could not delete from Newsno such table: News
2015/09/13 13:11:17 7dc2c93a 7ccc9296 DEBUG Could not insert into News-Tableno such table: News
2015/09/13 13:11:17 7dc2c93a 7ccc9296 INFO Starting instance ts3server://127.0.01?port=9987&nickname=Musik&password=&channel=&channelpassword=
2015-09-13 13:11:17.994093|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-09-13 13:11:17.994739|INFO | | | SystemInformation: Linux 2.6.32-042stab108.6 #1 SMP Thu Jul 9 13:40:24 MSK 2015 x86_64 Binary: 64bit
terminate called after throwing an instance of 'std::runtime_error'
what(): locale::facet::_S_create_c_locale name not valid
2015/09/13 13:11:17 7dc2c93a 7ccc9296 INFO TSClient quit.
2015/09/13 13:11:26 7dc2c93a 53465aad WARN Could not delete from Profilesno such table: Profiles
2015/09/13 13:11:26 7dc2c93a 53465aad WARN Could not insert into Profiles-Tableno such table: Profiles
2015/09/13 13:11:26 7dc2c93a 53465aad DEBUG Could not delete from Notificationsno such table: Notifications
2015/09/13 13:11:26 7dc2c93a 53465aad DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/09/13 13:11:26 7dc2c93a 53465aad DEBUG Could not delete from Newsno such table: News
2015/09/13 13:11:26 7dc2c93a 53465aad DEBUG Could not insert into News-Tableno such table: News
2015/09/13 13:11:26 7dc2c93a 53465aad INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=Toxic%20Musik&password=&channel=&channelpassword=
2015-09-13 13:11:26.683350|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-09-13 13:11:26.683485|INFO | | | SystemInformation: Linux 2.6.32-042stab108.6 #1 SMP Thu Jul 9 13:40:24 MSK 2015 x86_64 Binary: 64bit
2015/09/13 13:11:26 7dc2c93a 53465aad INFO TSClient quit.
2015/09/13 13:11:37 7dc2c93a 53465aad DEBUG Storing configuration.
2015/09/13 13:11:37 7dc2c93a 7ccc9296 DEBUG Storing configuration.
System:
Debian 7 minimal
512MB RAM
50GB SSD
Firefox mit ADBlock plus
Config.ini Keine Änderung, außer youtube-dl und Log von 3 auf 10
MfG SyntoxicTech
Moin :)
try mal: apt-get install locales
und danach: dpkg-reconfigure locales
scheint an der minimal Installation von Debian zu liegen ;)
