Bug Komische Logausgaben
Apollo3141
Betriebssystem: Linux Ubuntu Server 16.04 (x64 4.4.0-21-generic)
TS3 Version: 3.0.19.4
Problembeschreibung
Ich habe iwie ganz komische Log Ausgaben, die mein Log sehr unübersichtlich machen kann man die iwie abschalten ohne die Log Tiefe zu verlieren?
Beispiel:
2017/03/01 02:01:29 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8135/DESC
2017/03/01 02:01:29 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8136/DESC
2017/03/01 02:01:29 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8136/DESC
2017/03/01 02:01:29 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8137/DESC
2017/03/01 02:01:29 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8137/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8138/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8138/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8139/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8139/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8140/DESC
2017/03/01 02:01:30 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8140/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8141/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8141/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8142/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8142/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8143/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8143/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8144/DESC
2017/03/01 02:01:31 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8144/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8145/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8145/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8146/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8146/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8147/DESC
2017/03/01 02:01:32 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8147/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8148/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8148/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8149/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8149/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8150/DESC
2017/03/01 02:01:33 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8150/DESC
2017/03/01 02:01:34 ddf5a3f3 076dfb9d DEBUG  Awaiting Callback (1): PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8151/DESC
2017/03/01 02:01:34 ddf5a3f3 076dfb9d DEBUG  Found Callback PR:{a95f5f92-aff1-4f15-8dbd-ce5e0a585631}:8151/DESC
Da ich erst kürzlich nach einem Problem suchen musste und diese Ausgaben schon störend sind hoffe ich, dass es eine Lösung gibt sieht ja aus, als ob er einfach nur ausgibt, dass er auf die Ausgabge der mp3,wma.... Dateien wartet und das dann jede Sekunde...
das sind Debug Meldungen ^^ LogLevel in der Config.ini runter auf 3 und die sind weg.
Apollo3141
Das ist mir auch klar, dass das Debug Meldungen sind aber mein Problem ist, dass ich eben das Log Level nicht runter machen will, damit ich sehe was zB. Youtube-dl macht und ausgibt da ich damit kürzlich probleme hatte. Das wird bei einem niedrigen Log level aber net angezeigt... Und bei nem log level über 5 glaube ich werden die Meldungen schon angezeigt und dann erkennt man gar nichts mehr...
Reddexo
Speicher das Log doch einfach in eine Datei ab. Dann können dir die Debug Meldungen egal sein weil du das gesamte Log anschauen kannst.
Schau in deine config.ini da solltest du LogFile = "" finden.
Ich hoffe mal das löst dein Problem.
