EN Need help with replace()
SlamaFR
Hi !
I'm currently developping a support script and I need to replace some string like "%p" or "%n", but I can't simply do :
client.chat(config.messageToUser.replace('%p', config.prefix).replace('%n', client.nick));
It tells me :
Error in script: RangeError: expected 0 argument(s); got 3
Any idea ? :p
Sure that this Line is the Reason of the Error?
Maybe you want to show us a bit more of your Script or your Error Log, would be for sure helpful
Check if you really got a string in your config :p
SlamaFR
=> tried with client.nick()
Still, the error confuses me as well :/
YEP ! That was the problem..
Do you know a method to send a message to all users that are in a servergroup ? I mean, you give "45,23,64,etc' in the config and the bot send a message to all users in these servergroup..
SimoBot
https://www.sinusbot.com/docs/scripting/#Backend.getClients
there is an example. You have to check the server group of the user before sending the message with client.getServerGroups() that gives you an array with a servergroup object (made up with name and id). Run through the servergroup.id and check the servergroup id.
SlamaFR
I tried this but doesn't work :/
function notifyStaff(client, channel) {
        backend.getClients().forEach(function (c) {
            c.getServerGroups().forEach(function (g) {
                engine.log(g.ID());
                if (staff.indexOf(g.ID()) > 0) {
                    engine.log('sending to '+c.name());
                    switch(config.messageToStaffMethod) {
                        case "0":
                            client.chat(config.messageToStaff.replace('%p', config.prefix).replace('%n', client.nick()).replace('%c', channel.name()));
                            break;
                        case "1":
                            engine.log('Poke function unavailable');
                            break;
SlamaFR
Well, actually the code works and log me the ID of each group.
In my config, I have a string field in my config which basically get the groups corresponding to staff, e.g. "23,24,35". And I just want to check all the groups of all the clients to determine which clients must be notified.
