Feature New type 'checkbox', Fix for settings, Pattern for input
VJean
1. Need type: 'checkbox' for settings. Types
This setting it's bad usabelity:
PHP:
vars: {
  selectOne: {
    title: 'check it',
    type: 'select',
    options: ['yes','no']
2. Fix for Script page. Add <label for="id" />
Current view:
HTML:
<h4 class="ng-binding ng-scope" ng-if="!script.enableWeb" style="margin-bottom: 3px;">
<input class="ng-pristine ng-untouched ng-valid" ng-model="settings[scriptName].enabled" value="1" style="margin-right: 6px;" ng-hide="script.autorun" type="checkbox">
Advertising (Text)
<small class="ng-binding">2.0 by Michael Friese &lt;[email protected]&gt;, Raphael Touet &lt;[email protected]&gt; (advertising)</small>
</h4>
Change to:
HTML:
<input id="advertising" class="ng-pristine ng-untouched ng-valid" ng-model="settings[scriptName].enabled" value="1" style="margin-right: 6px;" ng-hide="script.autorun" type="checkbox">
<label for="advertising"> Advertising (Text)</label>
</h4>
3. Add var and value "patern" for input tag. http://www.w3schools.com/tags/att_input_pattern.asp
PHP:
vars: {
  stringPatern: {
    title: 'sample string patern',
    type: 'string',
    pattern: '[A-Za-z]{3}'
generated to setting:
HTML:
<input ng-if="var.type == 'string'" ng-model="settings[var.name]" class="form-control ng-pristine ng-untouched ng-valid ng-scope" id="f__adminUids" placeholder="" type="text" pattern="[A-Za-z]{3}>
Ack^^ Will work on that.
However, the pattern thing will require more love: it'd require server side checking as well and thus compatibility between front- and backend. Will think about that :)
VJean
@flyth, Then can not ask about global variables/functions, import modules, FileIO, Sockets and plugin2plugin interaction? )
Already required wrapper for frequently used functions: the "right" to ask the author and titles, time conversion, etc.
Imports are planned, however "shared" resources are not. Scripts run in loosely isolated environments as otherwise they would be prone to conflicts that may cause unwanted side effects.
However, you can pass data from script to script using
sinusbot.broadcast('foobar', { a: 1 });
and receive via
sinusbot.on('broadcast:foobar', function(data) { ... });
