Wzzloch90
Hi guys,
i recently installed Sinusbot on my Linux-Debian-vServer several times manually and then two times with the automated installation script.
And it'll never connect to the Webconsole.
Now, after changing out ports, enabling and disabling SSL , trying new users to host the session and trying out other directories i really don't have a clue anymore. So I'll ask you, maybe I am overlooking something pretty simple or you guys can spot anything suspicious in the config-files.
Do i need to configure something with ip-tables?
Here's my Debugscript-Output:
Log File:
also the service seems starting properly
even the right port is listening:
config-File:
Thanks,
Wzzloch90
- Operating System: Debian GNU/Linux 8.7 (jessie) (OpenVZ)
- Kernel: Linux 2.6.32-042stab116.2 x86_64
- Load Average: 0.00 0.00 0.00
- Uptime: 1 days, 0 hours, 52 minutes, 9 seconds
- OS APT Last Update: 13.04.2017 05:32:20 EDT -04:00:00
CPU(s): 24
CPU MHz: 2100.107
Virtualization: VT-x
- RAM: B/2.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 4.50 GB/14.04 GB in use (32%)
> libglib: 2.42.1-1+b1
- Status: running (PIDs: 31881 31880, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: aa67b784b83f5a7e66c60496f58d4a92)
- Version: 0.9.18-8499d2c
- Bot Plugin: d53693319c8922b95257ad4c6eacff69
- TS3 Client: d53693319c8922b95257ad4c6eacff69
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.04.11)
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; me
tadata.js; norecording.js; rememberChannel.js; showcase.js; sound.js; welcometext.js
- Report date: 13.04.2017 06:08:50 EDT -04:00:00 (timezone: America/New_York)
- youtube-dl Version: 2017.04.11
- DiagScript version: 0.5.1
Log File:
017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/04/13 07:24:13 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2017/04/13 07:24:13 X [MAIN] Starting up fake x-server...
2017/04/13 07:24:14 fd7aa696 INFO Loading instances
2017/04/13 07:24:14 fd7aa696 INFO Loading instance://4da7cd8f-0d13-4e2e-b62d-316d5d09dc40
2017/04/13 07:24:14 fd7aa696 4da7cd8f INFO Initialization complete
2017/04/13 07:24:14 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/04/13 07:24:14 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/04/13 07:24:14 [GENERAL/YTDL ] INFO youtube-dl checking...
2017/04/13 07:24:15 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2017/04/13 07:24:15 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://134.255.233.40:8087
2017/04/13 07:24:15 [GENERAL/RADIO ] INFO RadioStation data loaded
2017/04/13 07:24:15 [GENERAL/RADIO ] INFO Imported radio stations
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/04/13 07:25:21 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
service sinusbot restart
Restarting sinusbot...
sinusbot restarted successfully
root@mbzserver:/opt/sinusbot# lsof -i | grep 8087
sinusbot 1921 sinusbot 14u IPv4 9843754 0t0 TCP mbzserver.mogschboyz:8087 (LISTEN)
config-File:
3Path = "/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64"
ListenHost = "134.255.233.40"
SSLKeyFile = "/etc/ssl/private/ssl-cert-******.key"
SSLCertFile = "/etc/ssl/certs/ssl-cert-******.pem"
Hostname = "mogschboyz.de"
EnableWebStream = true
LogFile = "./logs.txt"
LicenseKey = "FQlKaprJGIfgmY6f9wgA7PqZ9UKhPrO/*yUB0I="
UserAgent = "SinusBot (0.9.18-8499d2c)"
Thanks,
Wzzloch90
