Bug No sound on
kavimodz
Operating System: Linux
SinusBot Version:0.9.15
TS3 Version: 3.x.x
I installed sinusbot via the script installer on an ovh server, i am able to access it but no sound output.
2016-12-23T12:49:32+05:30 [metadata] Searching for thumbnail for undefined - undefined
2016-12-23T12:49:32+05:30 PLAY [admin] aa918ee7-7add-4e63-a513-406c44e44c00 OK
2016-12-23T12:49:26+05:30 PLAY [admin] 6566bf7c-dee0-43a1-b29f-b6ae2fc2f9ed OK
2016-12-23T12:49:25+05:30 PLAY [admin] 6566bf7c-dee0-43a1-b29f-b6ae2fc2f9ed OK
2016-12-23T12:49:18+05:30 PLAY [admin] 1642238e-a692-4aee-b49d-6b314b74cc80 OK
2016-12-23T12:46:37+05:30 SAMPLEX 2880 60
2016-12-23T12:42:50+05:30 PLAY [admin] 1642238e-a692-4aee-b49d-6b314b74cc80 OK
2016-12-23T12:41:00+05:30 PLAY [admin] 6566bf7c-dee0-43a1-b29f-b6ae2fc2f9ed OK
2016-12-23T12:40:58+05:30 TSClient quit.
2016-12-23T12:40:57+05:30 New connection status 0; Error 1797
2016-12-23T12:40:57+05:30 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong or the security level of your identity is too low.
2016-12-23T12:40:57+05:30 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2016-12-23T12:40:57+05:30 TS |INFO |ClientUI |1 |Connect status: Disconnected
2016-12-23T12:40:53+05:30 TS |INFO |LicenseViewer | |Found cached license for version 1 and language en
2016-12-23T12:40:53+05:30 TS |INFO |LicenseViewer | |License language: en
2016-12-23T12:40:53+05:30 TS |INFO |Update | |Check license version: 1
2016-12-23T12:40:52+05:30 TS |INFO |Update | |Checking for updates...
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |Checking for update
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |Last update check was: Sun Jan 1 00:00:01 2017
2016-12-23T12:40:52+05:30 New connection status 1; Error 0
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI |1 |Connect status: Connecting
2016-12-23T12:40:52+05:30 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI |1 |Blacklist check ok
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=KaviAir&password=&channel=&channelpassword=
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data//ts3/4ba7f256-ae4f-4e3c-83be-c6f8f8a571ec/a6bcfb4c-4869-4786-9bb5-895a34e3a6ef/settings.db
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |Qt version: 5.5.1
2016-12-23T12:40:52+05:30 TS |INFO |ClientUI | |Failed to init text to speech engine
2016-12-23T12:40:52+05:30 TS |INFO |Query | |listening on 127.0.0.1:25639
2016-12-23T12:40:52+05:30 TS |INFO | | |Loading plugin: libtest_plugin
2016-12-23T12:40:52+05:30 TS |INFO | | |Loading plugin: libsoundbot_plugin
2016-12-23T12:40:52+05:30 TS |INFO | | |Loading plugin: liblua_plugin
2016-12-23T12:40:52+05:30 TS |INFO | | |Loading plugin: libclientquery_plugin
2016-12-23T12:40:52+05:30 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2016-12-23T12:40:52+05:30 TS |INFO | | |Using hardware aes
2016-12-23T12:40:52+05:30 TS |INFO | | |SystemInformation: Linux 3.10.0-514.2.2.el7.x86_64 #1 SMP Tue Dec 6 23:06:41 UTC 2016 x86_64 Binary: 64bit
2016-12-23T12:40:52+05:30 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2016-12-23T12:40:52+05:30 Starting instance ts3server://127.0.0.1?port=9987&nickname=KaviAir&password=&channel=&channelpassword=
2016-12-23T12:40:48+05:30 SAMPLEX 3840 60
2016-12-23T12:40:48+05:30 STOP [admin] OK
2016-12-23T12:40:47+05:30 PLAY [admin] 1642238e-a692-4aee-b49d-6b314b74cc80 OK
2016-12-23T12:40:46+05:30 SAMPLEX 3840 60
2016-12-23T12:40:45+05:30 STOP [admin] OK
2016-12-23T12:40:38+05:30 PLAY [admin] 1642238e-a692-4aee-b49d-6b314b74cc80 OK
2016-12-23T12:38:13+05:30 SAMPLEX 2880 60
2016-12-23T12:34:26+05:30 PLAY [admin] 1642238e-a692-4aee-b49d-6b314b74cc80 OK
2016-12-23T12:34:25+05:30 TSClient quit.
2016-12-23T12:34:24+05:30 New connection status 0; Error 1797
2016-12-23T12:34:24+05:30 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong or the security level of your identity is too low.
2016-12-23T12:34:24+05:30 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2016-12-23T12:34:24+05:30 TS |INFO |ClientUI |1 |Connect status: Disconnected
2016-12-23T12:34:23+05:30 PLAY [admin] 6566bf7c-dee0-43a1-b29f-b6ae2fc2f9ed OK
2016-12-23T12:34:19+05:30 TS |INFO |LicenseViewer | |Found cached license for version 1 and language en
2016-12-23T12:34:19+05:30 TS |INFO |LicenseViewer | |License language: en
2016-12-23T12:34:19+05:30 TS |INFO |Update | |Check license version: 1
2016-12-23T12:34:19+05:30 TS |INFO |Update | |Checking for updates...
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI | |Checking for update
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI | |Last update check was: Sun Jan 1 00:00:01 2017
2016-12-23T12:34:19+05:30 New connection status 1; Error 0
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI |1 |Connect status: Connecting
2016-12-23T12:34:19+05:30 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI |1 |Blacklist check ok
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2016-12-23T12:34:19+05:30 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=KaviAir&password=&channel=&channelpassword=
2016-12-23T12:34:18+05:30 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data//ts3/4ba7f256-ae4f-4e3c-83be-c6f8f8a571ec/a6bcfb4c-4869-4786-9bb5-895a34e3a6ef/settings.db
2016-12-23T12:34:18+05:30 TS |INFO |ClientUI | |Qt version: 5.5.1
2016-12-23T12:34:18+05:30 TS |INFO |ClientUI | |Failed to init text to speech engine
2016-12-23T12:34:18+05:30 TS |INFO |Query | |listening on 127.0.0.1:25639
2016-12-23T12:34:18+05:30 TS |INFO | | |Loading plugin: libtest_plugin
2016-12-23T12:34:18+05:30 TS |INFO | | |Loading plugin: libsoundbot_plugin
2016-12-23T12:34:18+05:30 TS |INFO | | |Loading plugin: liblua_plugin
2016-12-23T12:34:18+05:30 TS |INFO | | |Loading plugin: libclientquery_plugin
2016-12-23T12:34:18+05:30 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2016-12-23T12:34:18+05:30 TS |INFO | | |Using hardware aes
2016-12-23T12:34:18+05:30 TS |INFO | | |SystemInformation: Linux 3.10.0-514.2.2.el7.x86_64 #1 SMP Tue Dec 6 23:06:41 UTC 2016 x86_64 Binary: 64bit
2016-12-23T12:34:18+05:30 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2016-12-23T12:34:18+05:30 Starting instance ts3server://127.0.0.1?port=9987&nickname=KaviAir&password=&channel=&channelpassword=
2016-12-23T12:33:45+05:30 Auto-Playing last track
2016-12-23T12:33:44+05:30 Last track was 5b45a116-d6bc-4d0b-9488-088e35d1e969, will auto-play soon
2016-12-23T12:33:44+05:30 Initialization complete
2016-12-23T12:33:44+05:30 Loading script metadata
2016-12-23T12:33:44+05:30 Loading script welcometext
2016-12-23T12:33:44+05:30 Loading script advertising
2016-12-23T12:33:44+05:30 Loading script sound
2016-12-23T12:33:44+05:30 [Change Channelcodec And Quality Automaticly] Change Codec Load
2016-12-23T12:33:44+05:30 Loading script Change Channelcodec And Quality Automaticly
