henrik
Version: 0.9.8 with ts client 3.0.18.2
OS: Ubuntu 15.10
HW: Dedicated with OVH, i7, 32gb ram
Browser: Chrome
I'm running the bot off a dedicated server with OVH with the generic kernel (not the OVH one) and can't get the sound to work. If I start a song from the web interface it looks like it's playing and the bots log gives no errors, but there's no sound on TS.
Output from your diagnostic tool:
Config.ini:
Sorry to bother you if this is something super simple. I've been trying to fix it since last night, but I'm out of ideas (and google searches..)
OS: Ubuntu 15.10
Browser: Chrome
- Operating System: Ubuntu 15.10
- Kernel: Linux 4.2.0-19-generic x86_64
- Load Average: 1.21 1.23 1.04
- Uptime: 0 days, 0 hours, 25 minutes, 59 seconds
- OS Updates: 50 (updates available!)
- OS APT Last Update: 06.12.2015 07:40:35 CET +01:00:00
CPU(s): 8
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
Model name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
CPU MHz: 1827.968
- RAM: 5.31 GB/31.30 GB in use (16%)
- SWAP: 0 B/1021.99 MB in use (0%)
- DISK: 37.77 GB/184.28 GB in use (20%)
- Report date: 07.12.2015 05:29:03 CET +01:00:00 (timezone: Europe/Paris)
- Status: running (PIDs: 3992, User: teamspeak-bots)
- Binary: /opt/ts3soundboard/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
- Version: unknown
- YoutubeDLPath = not set
- Installed Scripts: config.ini config.ini.dist data diagSinusbot.sh libavcodec.so.56 libavformat.so.56 libavutil.so.54 libswresample.so.1 plugin README.md sinusbot-0.9.8.tar.bz2 TeamSpeak3-Client-linux_amd64 TeamSpeak3-Client-linux_amd64-3.0.18.2.run ts3bot
Config.ini:
SecretKey = [236, 62, 126, 110, 87, 180, 150, 82, 139, 76, 99, 109, 1, 207, 224, 27, 184, 228, 238, 208, 210, 30, 66, 159, 49, 4, 24, 191, 27, 47, $
EnableDebugConsole = true
MTU = 1500
SampleInterval = 100
