Not opening TS
Senaphur
Betriebssystem: Linux Debian
SinusBot Version: 0.9.x
TS3 Version: 3.x.x (die vom Script installiert wird, wahrscheinlich die neuste)
Problembeschreibung
Habe die Stufe auf 10 gesetzt und immer wenn ich den Server starten will kriege ich die antwort hier.
sinusbot@Server:/opt/sinusbot$ ./sinusbot
Version: 0.9.16-10f0fad
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2017/01/20 02:47:31 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2017/01/20 02:47:31 X [MAIN] Starting up fake x-server...
2017/01/20 02:47:31 ce40bdf2          INFO   Loading instances
2017/01/20 02:47:31 ce40bdf2          INFO   Loading instance://4116e2d0-5599-40d9-ac5e-daa8252932af
2017/01/20 02:47:31 ce40bdf2 4116e2d0 DEBUG  Spawning instance shortly due to missing configuration file.
2017/01/20 02:47:31 ce40bdf2 4116e2d0 INFO   Initialization complete
2017/01/20 02:47:31 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/01/20 02:47:31 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 format
2017/01/20 02:47:31 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2017/01/20 02:47:31 ce40bdf2 4116e2d0 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&passsword=
2017/01/20 02:47:31 X [MAIN] New connection
2017/01/20 02:47:31 ce40bdf2 4116e2d0 DEBUG  TS>Could not initialize GLX
2017/01/20 02:47:31 ce40bdf2 4116e2d0 DEBUG  Closed.
2017/01/20 02:47:31 ce40bdf2 4116e2d0 INFO   TSClient quit. LogLevel has been increased, please try to connect again
2017/01/20 02:47:33 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2017/01/20 02:47:33 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://
2017/01/20 02:47:33 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2017/01/20 02:47:35 [GENERAL/RADIO  ] INFO   Imported radio stations
2017/01/20 02:47:49 ce40bdf2 4116e2d0 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&passsword=
2017/01/20 02:47:49 X [MAIN] New connection
2017/01/20 02:47:49 ce40bdf2 4116e2d0 DEBUG  TS>Could not initialize GLX
2017/01/20 02:47:49 ce40bdf2 4116e2d0 DEBUG  Closed.
2017/01/20 02:47:49 ce40bdf2 4116e2d0 INFO   TSClient quit. LogLevel has been increased, please try to connect again
2017/01/20 02:48:01 ce40bdf2 4116e2d0 DEBUG  Storing configuration.
verstehe nur nicht warum es nicht geht, hab doch richtig angegeben das der server nicht auf 127.0.0.1 läuft.
oder von welchem log reden wir?
EDIT: Hat sich erledigt, Chat hat geholfen. Funktioniert jetzt.
