EN Own script problem
BisKit
Hi !
I try to script a plugin that will start when client joins "channel1" and move him to "channel2".
I put it in /opt/sinusbot/scripts directory, but I don't see it in scripts (in sinusbot options). I tried restarts. Other plugins work well.
registerPlugin({
    version: '1.0',
    description: 'Simple move client script',
    author: 'BisKit ([email protected])',
    vars: {
        channelone: {
            title: 'channel1',
            type: 'channel',
        channeltwo: {
            title: 'channel2',
            type: 'channel',
    sinusbot.on('clientMove', function(ev)) {
        if (ev.newChannel == config.channelone)
            sinusbot.move(ev.clientId, config.channeltwo);
            return;
    sinusbot.log('ChannelMove Plugin Initialized.');
Hi !
registerPlugin({
    version: '1.0',
    vars: {
        channelone: {
            title: 'channel1',
            type: 'channel',
        channeltwo: {
            title: 'channel2',
            type: 'channel',
            return;
you missed a curly bracket after the if condition. This one should work:
http://hastebin.com/uhojunosud.vbs
At the next time, if you have such a problem, first check the logs, when the bot starts, there should be the error message. ;)
kanalumaddela
I wanted to try the script, but for some reason it still wasn't working. After looking through the script multiple times (I hate losing track of parentheses in code tbh), I found the error.
You had
instead of
sinusbot.on('clientMove', function(ev) {
registerPlugin({
    version: '1.0',
    vars: {
        channelone: {
            title: 'Channel to move client from',
            type: 'channel'
        channeltwo: {
            title: 'Channel to move client to',
            type: 'channel'
        if (ev.newChannel == config.channelone) {
            return;
Also tested that^ and it works, so nice job.
