Problem when SinusBot Start
RazvanGFX
2019-10-05T15:59:34+01:00 eof from data
2019-10-05T15:59:34+01:00 closing channels
2019-10-05T15:59:34+01:00 eof from voice
2019-10-05T15:59:33+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-10-05T15:59:33+01:00 Closed.
2019-10-05T15:59:33+01:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2019-10-05T15:59:33+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-10-05T15:59:33+01:00 TS>QStandardPaths: wrong ownership on runtime directory /run/user/1000, 1000 instead of 1003
2019-10-05T15:59:33+01:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-10-05T15:59:33+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-10-05T15:59:33+01:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019-10-05T15:59:33+01:00 TS |INFO |Addons | |Checking for addon updates...
2019-10-05T15:59:33+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-10-05T15:59:33+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-10-05T15:59:33+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-10-05T15:59:33+01:00 TS |INFO | | |Using hardware aes
2019-10-05T15:59:33+01:00 TS |INFO | | |SystemInformation: Linux 4.4.0-142-generic #168~14.04.1-Ubuntu SMP Sat Jan 19 11:26:28 UTC 2019 x86_64 Binary: 64bit
2019-10-05T15:59:33+01:00 TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019-10-05T15:59:33+01:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/f4bbc26c-4fba-4f5a-9cda-e1ef9464756b/7a896334-6b4b-4170-ba07-88e24f118a4b/crashdumps
2019-10-05T15:59:33+01:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/f4bbc26c-4fba-4f5a-9cda-e1ef9464756b/7a896334-6b4b-4170-ba07-88e24f118a4b/crashdumps
2019-10-05T15:59:33+01:00 Starting instance ts3server://ts.cspower.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-10-05T15:59:33+01:00 Could not insert into News-Tableno such table: News
2019-10-05T15:59:33+01:00 Could not delete from Newsno such table: News
2019-10-05T15:59:33+01:00 Could not insert into Profiles-Tableno such table: Profiles
2019-10-05T15:59:33+01:00 Could not delete from Profilesno such table: Profiles
2019-10-05T15:59:33+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-10-05T15:59:33+01:00 Could not delete from FileTransferno such table: FileTransfer
2019-10-05T15:59:33+01:00 About to run.
2019-10-05T15:59:33+01:00 Prespawn.
2019-10-05T15:59:32+01:00 BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2019-10-05T15:59:26+01:00 Storing configuration.
2019-10-05T15:58:58+01:00 eof from data
2019-10-05T15:58:58+01:00 eof from voice
2019-10-05T15:58:58+01:00 closing channels
2019-10-05T15:58:57+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-10-05T15:58:57+01:00 Already online.
2019-10-05T15:58:57+01:00 TS |INFO |Addon | |Not available for this platform.
2019-10-05T15:58:57+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-10-05T15:58:57+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-10-05T15:58:57+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-10-05T15:58:57+01:00 TS |INFO |Addons | |Checking for addon updates...
2019-10-05T15:58:57+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-10-05T15:58:57+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-10-05T15:58:57+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-10-05T15:58:57+01:00 TS |INFO | | |Using hardware aes
2019-10-05T15:58:57+01:00 TS |INFO | | |SystemInformation: Linux 4.4.0-142-generic #168~14.04.1-Ubuntu SMP Sat Jan 19 11:26:28 UTC 2019 x86_64 Binary: 64bit
2019-10-05T15:58:57+01:00 TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019-10-05T15:58:56+01:00 script command loaded
2019-10-05T15:58:56+01:00 Auto-Starting f4bbc26c-4fba-4f5a-9cda-e1ef9464756b/7a896334-6b4b-4170-ba07-88e24f118a4b in 500 ms...
2019-10-05T15:58:56+01:00 Initialization complete
2019-10-05T15:58:56+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
