Version: 0.9.15-b20cc30
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin animatedNick.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/12/02 03:19:48 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/12/02 03:19:48 X [MAIN] Starting up fake x-server...
2016/12/02 03:19:53 Error on database operations: database is locked
2016/12/02 03:19:53 This usually happens, if the bot user does not own the database files (e.g. when you first ran the bot as user root but now moved to another user). To fix this, please make sure that the bot user owns the entire data directory.
____________________________________________
I'm getting this error when i start bot. Yesterday i installed a bot all worked perfect. and today i saw that my panel where i login in to bot is slowly loading, i stoped the bot from there and tried to start it again and all stoped there. I tried to update sinusbot, and also i set the start/stop/restart script. but when i start script like from /opt/ts3soundboard with ./sinusbot it shows this error above.
Can anyone help me with this?
Many thanks!
Many thanks!
