Poke7z
Hey i want to use the Bot :3 i have the Newest Version and here are the Logs:
Sinusbot Version: 1.0.0-beta.10-202ee4d
Teamspeak Client Version: 3.5.6
Teamspeak Server Version: 3.13.2
OS: Ubuntu 20.04 LTS
The Sinusbot is Running on Pterodactyl :3 also it use it's own Install Script so if this is the Problem :3
___ ___ _ _ _ _ ___ ___ ___ _____
Generating new bot instance with account 'admin' and password '1mdBsPEo'
2020/12/18 01:16:49 Updating database to v1... 0
2020/12/18 01:16:49 Updating database to v2... 1
2020/12/18 01:16:49 Updating database to v3... 2
2020/12/18 01:16:49 Updating database to v4... 3
2020/12/18 01:16:49 Updating database to v5... 4
2020/12/18 01:16:49 Updating database to v6... 5
2020/12/18 01:16:49 Updating database to v7... 6
2020/12/18 01:16:49 Updating database to v8... 7
2020/12/18 01:16:49 415c9a15 INFO Loading instances
2020/12/18 01:16:49 415c9a15 INFO Creating default instance
2020/12/18 01:16:49 415c9a15 111c7aaf INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2020/12/18 01:16:49 415c9a15 111c7aaf INFO script command loaded
2020/12/18 01:16:49 415c9a15 INFO Promoting instance to main instance
2020/12/18 01:16:49 415c9a15 111c7aaf PLUGIN [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020/12/18 01:16:49 415c9a15 111c7aaf INFO script sinusbot-commands loaded
2020/12/18 01:16:49 415c9a15 INFO Added new user admin
2020/12/18 01:16:49 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2020/12/18 01:16:49 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2020/12/18 01:16:49 [GENERAL/YTDL ] INFO youtube-dl checking...
2020/12/18 01:16:49 X [MAIN] New connection
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |SystemInformation: Linux 5.4.0-54-generic #60-Ubuntu SMP Fri Nov 6 10:37:59 UTC 2020 x86_64 Binary: 64bit
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |Using hardware aes
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |DEBUG |PulseAudio | |connected to pulse audio server -
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |Addons | |Checking for addon updates...
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |SyncImpl | |Creating default config in local storage
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |Addon | |Not available for this platform.
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |successfully downloaded revocation list for accounting
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |*** Time [MAINWINDOW]: 307
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO | | |*** Time [INIT]: 307
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Qt version: 5.12.1
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Using configuration location: /home/container/data/ts3/415c9a15-43a7-432a-973f-fc155d97e1df/111c7aaf-7709-4ec0-9bb4-255f06e7603b/settings.db
2020/12/18 01:16:49 415c9a15 111c7aaf INFO TS |INFO |Addon_Download_Manager| |Download completed: /tmp/clientquerypluginlinuxamd64_5d2d9a738ad98.ts3_plugin Addon_Uuid:943dd816-7ef2-48d7-82b8-d60c3b9b10b3 Version: 7
2020/12/18 01:16:50 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2020/12/18 01:16:50 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2020/12/18 01:16:50 [GENERAL/RADIO ] INFO Could not find RadioStation-Data (or outdated), updating...
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Last update check was: Never
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |Update | |Checking for updates...
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |Integrations | |Requesting integration icon download from https://ts3services.teamspeak.com/integration_icons/twitch/twitch.svg
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |Update | |License update available; version 0 to 5 (min version 0 to 4)
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |LicenseViewer | |View license: version=5, language=C, require accept=1
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |LicenseViewer | |Requesting remote license for version 5 and language C
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |LicenseViewer | |Failed to download license file for version 5 and language C, retrying english fallback
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |LicenseViewer | |Requesting remote license for version 5 and language en
2020/12/18 01:16:50 415c9a15 111c7aaf INFO TS |INFO |LicenseViewer | |Downloaded license file for version 5 and language en
2020/12/18 01:16:50 [GENERAL/RADIO ] INFO RadioStation data loaded
2020/12/18 01:16:51 [GENERAL/RADIO ] INFO Imported radio stations
2020/12/18 01:16:55 415c9a15 111c7aaf INFO TSClient quit.
2020/12/18 01:17:02 415c9a15 INFO LOGIN [admin] OK
2020/12/18 01:18:46 415c9a15 111c7aaf INFO BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC IDENTITY OK
2020/12/18 01:18:54 415c9a15 111c7aaf INFO BOT-CONFIG [admin] NICK CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2020/12/18 01:18:57 415c9a15 111c7aaf INFO Starting instance ts3server://45.142.179.86?port=9987&nickname=PokiBOT&password=&channel=&channelpassword=
2020/12/18 01:18:57 X [MAIN] New connection
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |INFO | | |SystemInformation: Linux 5.4.0-54-generic #60-Ubuntu SMP Fri Nov 6 10:37:59 UTC 2020 x86_64 Binary: 64bit
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |INFO | | |Using hardware aes
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |DEBUG |PulseAudio | |connected to pulse audio server -
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2020/12/18 01:18:57 415c9a15 111c7aaf INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |Addons | |Checking for addon updates...
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |successfully downloaded revocation list for accounting
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |*** Time [MAINWINDOW]: 131
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |*** Time [INIT]: 131
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Qt version: 5.12.1
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Using configuration location: /home/container/data/ts3/415c9a15-43a7-432a-973f-fc155d97e1df/111c7aaf-7709-4ec0-9bb4-255f06e7603b/settings.db
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |ts3server: 45.142.179.86?port=9987&nickname=PokiBOT&password=&channel=&channelpassword=
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI |1 |Connect to server: 45.142.179.86
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI |1 |Initiating connection: 45.142.179.86:9987
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2020/12/18 01:18:58 415c9a15 111c7aaf INFO New connection status 1; Error 0
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |DEVELOP |PktHandler |1 |Puzzle solve time: 2
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |Statistics report: First run, report later in 1-30 days
2020/12/18 01:18:58 415c9a15 111c7aaf INFO TS |INFO | | |Statistics report: Setting next report date to: Thu Jan 14 01:18:58 2021
2020/12/18 01:19:03 415c9a15 111c7aaf INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2020/12/18 01:19:03 415c9a15 111c7aaf INFO TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2020/12/18 01:19:03 415c9a15 111c7aaf INFO The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2020/12/18 01:19:03 415c9a15 111c7aaf INFO New connection status 0; Error 1797
2020/12/18 01:19:04 415c9a15 111c7aaf INFO TSClient quit.
