Before you post:
Please always include the following information in your post:
Please also don't post twitter-style. You are allowed to use more than 140 characters!
Structuring the post helps other people understand your problem better and will get you better responses.
If you've read this far and follow every step:
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- search for your issue on this forum.
- Also make sure you've read the FAQ / Documentation
- and verify you use the latest version of the SinusBot
- and of course your OS (operating system) is up to date.
- SinusBot version (in you web-interface under Settings -> Info -> About)
- TS Client and Server version
- OS (operating system), e.g. Windows 10 64bit or Debian 9 64bit
- on linux also the kernel version:
uname -a
- hardware specs (e.g. VPS, Core i7, 8 GB RAM)
- the instance log and bot log (set
in the config.ini before) - your config.ini
- used browser and plugins (only if it is relevant for the problem)
Thanks
