problem with youtube-dl
Platonius
Operating System: Linux
SinusBot Version: 0.9.21
TS3 Version: 3.0.19.4
I install youtube-dl well, on logs I see checking youtube-dl and also Version compatible but When I write !yt url or in admin panel on upload a yt url I receive Download failed for
youtube-dl download failed (check youtube-dl) Sorry for the link it is a example.
Instance logs:
2017/08/27 14:13:14 X [MAIN] Starting up fake x-server...
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin advertising.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin aloneMode.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin badchan.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin bookmark.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin covatar.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin dev.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin followme.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin idle.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin metadata.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin norecording.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin rememberChannel.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin showcase.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin sound.js
2017/08/27 14:13:15 [GENERAL/SCRIPTS] INFO  Loading ScriptPlugin welcometext.js
2017/08/27 14:13:15 9d78a227  INFO  Loading instances
2017/08/27 14:13:15 9d78a227  INFO  Loading instance://11d7b91b-cb94-4603-b80a-6412c3c83909
2017/08/27 14:13:15 9d78a227 11d7b91b INFO  Initialization complete
2017/08/27 14:13:15 9d78a227 11d7b91b INFO  Auto-Starting 9d78a227-1a97-4284-87d1-02f7f1585e0b/11d7b91b-cb94-4603-b80a-6412c3c83909 in 500 ms...
2017/08/27 14:13:15 [GENERAL/FFMPEG ] INFO  FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/08/27 14:13:15 [GENERAL/FFMPEG ] INFO  FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/08/27 14:13:15 [GENERAL/YTDL  ] INFO  youtube-dl checking...
2017/08/27 14:13:16 9d78a227 11d7b91b WARN  Could not create Chat-Tabletable Chat already exists
2017/08/27 14:13:16 9d78a227 11d7b91b WARN  Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017/08/27 14:13:16 9d78a227 11d7b91b WARN  Could not create Notifications-Tabletable Notifications already exists
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  Starting instance ts3server://127.0.0.1?port=9987&nickname=Pruebabot&password=&channel=&channelpassword=
2017/08/27 14:13:16 X [MAIN] New connection
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |SystemInformation: Linux 4.4.0-89-generic #112-Ubuntu SMP Mon Jul 31 19:38:41 UTC 2017 x86_64 Binary: 64bit
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |ERROR  |PulseAudio  |  |failed to connect to pulse audio server
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |ERROR  |PulseAudio  |  |pa_context_connect failed
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |ERROR  |SoundBckndIntf|  |/home/bot/bot1/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017/08/27 14:13:16 [GENERAL/YTDL  ] INFO  youtube-dl version compatible, support enabled
2017/08/27 14:13:16 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8089
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |Loading plugin: libclientquery_plugin
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |Loading plugin: liblua_plugin
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |Loading plugin: libsoundbot_plugin
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |  |  |Loading plugin: libtest_plugin
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |Query  |  |listening on 127.0.0.1:25639
2017/08/27 14:13:16 [GENERAL/RADIO  ] INFO  RadioStation data loaded
2017/08/27 14:13:16 [GENERAL/RADIO  ] INFO  Imported radio stations
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |  |Failed to init text to speech engine
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |  |Qt version: 5.5.1
2017/08/27 14:13:16 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |  |Using configuration location: /home/bot/bot1/data/ts3/9d78a227-1a97-4284-87d1-02f7f1585e0b/11d7b91b-cb94-4603-b80a-6412c3c83909/settings.db
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |  |ts3server: 127.0.0.1?port=9987&nickname=Pruebabot&password=&channel=&channelpassword=
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Connect to server: 127.0.0.1
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Blacklist check ok
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |PreProSpeex  |1  |Speex version: 1.2rc1
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Connect status: Connecting
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  New connection status 1; Error 0
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |  |Last update check was: mar. ene. 1 00:00:01 2019
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |  |  |Statistics report: Not yet, next report on vie. sept. 1 13:40:27 2017
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |DEVELOP |PktHandler  |  |Puzzle solve time: 4
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Connect status: Connected
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  New connection status 2; Error 0
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Connect status: Establishing connection
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  New connection status 3; Error 0
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |ClientUI  |1  |Connect status: Connection established
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  TS |INFO  |PermManager  |  |Loading permissions from cache
2017/08/27 14:13:17 9d78a227 11d7b91b INFO  New connection status 4; Error 0
