KNG Dxniel
Moin zusammen,
Wenn ich über das Sinusbot Installer Script den Sinusbot installieren will kommt immer wieder Fehler Meldungen ich habe zusätzlich wie im Post beschrieben das Script ausgeführt.
Dieser Fehler folgt bei der installation.
https://i.imgur.com/kfzTkon.png
[CODE]
- Operating System: Ubuntu 18.04.6 LTS
- Kernel: Linux 5.4.203-1-pve x86_64
- Load Average: 70.85 71.59 72.13
- Uptime: 6 days, 7 hours, 49 minutes, 30 seconds
- OS APT Last Update: 11.04.2024 23:37:16 CEST +02:00:00
- Shell Locale: de_DE.UTF-8
CPU(s): 128
Thread(s) per core: 0
Core(s) per socket: 32
Socket(s): 2
Model name: AMD EPYC 7542 32-Core Processor
CPU MHz: 3325.987
Virtualization: AMD-V
- RAM: 692.13 MB/6.00 GB in use (11%)
- DISK: 3.63 GB/39.07 GB in use (9%)
- libglib: 2.56.4-0ubuntu0.18.04.9
- Binary Info: MD5 Hash: 72d16bcac5d8e0df94ba49def894e52f, Perms: 755, User: admin
- Version:
- LogLevel =
- TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.5.6)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: )
/opt/sinusbot/sinusbot: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /opt/sinusbot/sinusbot)
/opt/sinusbot/sinusbot: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /opt/sinusbot/libavformat.so.59)
/opt/sinusbot/sinusbot: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /opt/sinusbot/libavutil.so.57)
linux-vdso.so.1 (0x00007ffe88f99000)
libswresample.so.4 => /opt/sinusbot/libswresample.so.4 (0x00007fde1cb0b000)
libavfilter.so.8 => /opt/sinusbot/libavfilter.so.8 (0x00007fde1c504000)
libavformat.so.59 => /opt/sinusbot/libavformat.so.59 (0x00007fde1c280000)
libavcodec.so.59 => /opt/sinusbot/libavcodec.so.59 (0x00007fde1afa0000)
libavutil.so.57 => /opt/sinusbot/libavutil.so.57 (0x00007fde1c930000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fde1ad7d000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fde1ab77000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fde1a958000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fde1a5cf000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fde1a231000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fde1a019000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fde19c28000)
/lib64/ld-linux-x86-64.so.2 (0x00007fde1c906000)
libswscale.so.6 => /opt/sinusbot/libswscale.so.6 (0x00007fde19b7b000)
- DNS resolution check: SUCCESS [www.sinusbot.com resolved to 104.21.13.58]
update03.sinusbot.com -> 104.21.13.58: SUCCESS [CODE #404]
- Time (local): 11.04.2024 23:57:35 CEST +02:00:00
- Time (remote): 11.04.2024 23:57:35 CEST +02:00:00
- TeamSpeak3 Version: 3.5.6
- youtube-dl Version:
