!qytdl skips queue
RSLak
Hello everyone,
when using !qytdl <url> the bot downloads the song from the url, but will then stop the currently playing song and instantly start the downloaded one instead of queuing it up. After the downloaded song finished playing, the queue will be continued.
!qyt <url> seems to be unaffected from this.
Sinusbot version: 0.14.3-0e747fd
OS: Ubuntu Server 18.04
Greetings
RSLak
Demoi
Gleiches Problem bei mir, !qyt funktioniert wie es soll, !qytdl spielt das lied sofort nach erfolgreichen herunterladen ab.
Sinusbot Version:
0.13.37-f37f203
OS: Windows 7 Ultimate 64 bit Service Pack 1
Hardware Specs:
CPU: Intel Core i5-2500k CPU Overclocked to 4Ghz
RAM: 24GB
Used Browser: Mozilla Firefox (Quantum 64.0.2 64 bit)
- Addons: NoScript, uBlock Origin, MyJDownloader Browser Erweiterung, Exif Viewer
Config.ini:
TS3Path = "M:\\SinusBot\\TeamSpeak 3 Client\\ts3client_win64.exe"
DataDir = "M:\\SinusBot\\data\\"
LogLevel = 3
YoutubeDLPath = "M:\\SinusBot\\youtube-dl.exe"
LicenseKey = "gRtrN1DHWHfM8RAJLDAC7+GC7rrAiJrWXLxV3Aifin0="
UserAgent = "SinusBot (0.13.37-f37f203)"
olokos
try youtube search plugin by @NT5
Just tested !qyt on sinusbot alpha build, it works as intended. You might have something wrong, but I'm running it under linux, so it might be another story.
Demoi
the normal !qyt works perfectly fine.
the command to download and save permanently !qytdl is buggy.
it downloads the song and play's it instantly, doesn't put in in the queue.
