reloading scripts gets timeout
Lukas Westholt
sometimes after I press the "save changes"-Button in the "script"-section of the sinusbot frontend, i get a never-ending red loadingbar at the top of the page and messages in instance log: "Could not request updateChannel". This message only comes when i press the save button (and this problem is appearing). The settings are getting saved without problems, but reloading all scripts needs ages and i have to restart sinusbot. This problem is only appearing sometimes.
2019-05-10T18:52:17+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:52:07+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:57+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:56+02:00 Could not upload avatar: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:47+02:00 script tunakills_ranking loaded
2019-05-10T18:51:46+02:00 script WeatherInformation loaded
2019-05-10T18:51:46+02:00 script Lyrics loaded
2019-05-10T18:51:46+02:00 script uptimerobot loaded
2019-05-10T18:51:46+02:00 [ uptimerobot:131:12] Loaded Uptimerobot - Server Status/Uptime Monitoring v3.0.2 by Jonas Bögle (irgendwr).
2019-05-10T18:51:46+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:36+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:26+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:16+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:51:06+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:58+02:00 banner file created: avatarbanner - took 1.623249036s
2019-05-10T18:50:56+02:00 script connectfour loaded
2019-05-10T18:50:56+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:46+02:00 [ connectfour:18:9] Connect Four Plugin loaded
2019-05-10T18:50:46+02:00 script tester loaded
2019-05-10T18:50:46+02:00 [ tester:22:20] not configured yet. Disabling it...
2019-05-10T18:50:46+02:00 [ tester:20:16] {}
2019-05-10T18:50:46+02:00 script jail loaded
2019-05-10T18:50:46+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:36+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:26+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:16+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:50:06+02:00 script countOnlineUsers loaded
2019-05-10T18:50:06+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:56+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:46+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:36+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:26+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:16+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:49:06+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:48:56+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:48:46+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T18:48:36+02:00 script away_mover loaded
2019-05-10T18:48:36+02:00 [ away_mover:582:20] [INFO] AFK mover (Away/Mute/Deaf/Idle) v2.4.0 by Jonas Bögle <[email protected]> loaded successfully.
2019-05-10T18:48:36+02:00 [ away_mover:582:20] [INFO] debug messages are disabled
2019-05-10T18:48:36+02:00 script pizzaTimer loaded
2019-05-10T18:48:36+02:00 script dice loaded
I use bot version 1.0.0-beta.1-06a54d7 and TeamSpeak 3 Client 3.2.5.
Just guessing, does it happen as well, when you disable Tuna's Ranking Script?
Cause I had that problem as well some time ago.
Lukas Westholt
Thank you @TwentyFour,
i tried it but the ranking script was not the problem. But now i disabled the digitalclock.js Script and so far it works. :D
EDIT:
In fact, the problem has indeed weakened significantly, but not quite gone. Loading is faster and there are fewer error messages:
2019-05-10T19:20:16+02:00 banner file created: avatarbanner - took 1.624312149s
2019-05-10T19:20:13+02:00 script V2.2_random_kick loaded
2019-05-10T19:20:13+02:00 [V2.2_random_kick:64:12] object
2019-05-10T19:20:13+02:00 [V2.2_random_kick:63:12] ["6"]
2019-05-10T19:20:13+02:00 Could not find request 51
2019-05-10T19:20:13+02:00 Could not find request 50
2019-05-10T19:20:13+02:00 script uptimerobot loaded
2019-05-10T19:20:13+02:00 [ uptimerobot:131:12] Loaded Uptimerobot - Server Status/Uptime Monitoring v3.0.2 by Jonas Bögle (irgendwr).
2019-05-10T19:20:13+02:00 script countOnlineUsers loaded
2019-05-10T19:20:13+02:00 Could not request updateChannel: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T19:20:03+02:00 script Random GIFs loaded
2019-05-10T19:20:03+02:00 script bird loaded
2019-05-10T19:20:03+02:00 script avatarbanner loaded
2019-05-10T19:20:03+02:00 Could not remove avatar: HTTP returned an error: Timeout; Code: 500; Message: Timeout
2019-05-10T19:19:53+02:00 script Youtube Search loaded
2019-05-10T19:19:53+02:00 script WelcomeMessagePlus loaded
2019-05-10T19:19:53+02:00 script tunakills_ranking loaded
2019-05-10T19:19:52+02:00 script tester loaded
Does anyone know what "Could not find request 50" means? Or "Count not request updateChannel"?
EDIT2: same problems as before.
