Solved Reset passwort not working
DiBaDu
Operating System: Linux Debian 8
SinusBot Version: 0.10.6-ea49bdc
TS3 Version: 3.0.19.4
Hello have the Same problem. I cant reset the passwort. Im using Version:
0.10.6-ea49bdc
If i use ./sinusbot -pwreset=foobar
I get this message
/opt/ts3soundboard$ ./sinusbot -pwreset=foobar
flag provided but not defined: -pwreset
Usage of ./sinusbot:
-delay
delay startup
-displayConfig
displays the current config
-gentoken
generate new auth-token
-initonly
prepare for first run only
-override-password string
override-password
It is only a temporary pw override, afaik.
So you need to reset the pw properly inside the Webinterface or use the command everytime.
and yes in your example the pw would get overridden to "password"
