This could either be an instance setting or maybe added to the script API where you can choose where songs are saved to.
I would rather see this in the scripting API as it gives a wider range of uses. An example could be 2 public bots where you want to separate the songs downloaded from one bot and songs from the other bot. Also where they are specific folders for specific clients to separate their music.
