EN say (tts) does not work via script anymore
BrAiNee
Hi i upgraded the bot from 0.13.37 to 1.0.0-alpha.5, now my greeting script does not work anymore.
This is the error:
error on callback func: Uncaught exception: ReferenceError: say is not defined at come:87:3 say("Sorry muss los", "de"); ^ Stack trace: ReferenceError: say is not defined at come:87:4
and this the code:
on 0.13.37 it was working fine, what should i change ?
BrAiNee
ok i found it out myself while reading other tts scripts i put a "const audio = require('audio');" line in it and changed "say" to "audio.say"
now it works
