SB startet und schmiert sofort wieder ab
AiR-Angelo
Hey Leute habe aktuell das Problem das sobald ich Sb starten möchte alles Instanzen verbinden und innerhalb von 5 sekunden alle wieder die Verbindung verlieren.
Benutze die neuste Alpha Version und habe hier mal den Output von meinem Diag
 - Operating System: Debian GNU/Linux 9.8 (stretch) (OpenVZ)
 - Kernel: Linux 2.6.32-openvz-042stab123.9-amd64 x86_64
 - Load Average: 0.21 0.16 0.14
 - Uptime: 0 days, 0 hours, 16 minutes, 3 seconds
 - OS APT Last Update: 17.02.2019 04:10:08 CET +01:00:00
 - RAM:  B/4.00 GB in use (%)
 - SWAP:  B/ B in use (%)
 - DISK: 2.10 GB/29.86 GB in use (7%)
   + libglib: 2.50.3-2
 - Binary Info: MD5 Hash: 6be140480cdf37bcb2f8a2e1f06a49f7, Perms: 755, User: root
 - Version: 1.0.0-alpha.5-9767656
   - Bot Plugin: 59d8f8244535ab73f5fcf321a5a404bf
   - TS3 Client: 59d8f8244535ab73f5fcf321a5a404bf
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.02.18)
 - Installed scripts: MessageToGroups_1_0.js; OKlib.js; PrivatChannelManager 2.0.4 (Angelo edit).js; ServerGroupTimer.js; auto        _channel_creator.js; away_mover.js; command.js; liftchannel.js; reconnect.js; rememberChannel.js; support-pp.js
 - Time (local): 21.02.2019 01:55:24 CET +01:00:00
 - TeamSpeak 3 Version: 3.2.3
 - youtube-dl Version: 2019.02.18
 - DiagScript Version: 0.7.1
Außerdem hier der Statusoutput den ich beim Starten des Service bekomme :
root@Airborne-Multigaming:/opt/sinusbot# systemctl status sinusbot
   Active: failed (Result: exit-code) since Thu 2019-02-21 01:49:25 CET; 10min ago
  Process: 2292 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
  Process: 1924 ExecStart=/opt/sinusbot/sinusbot (code=exited, status=255)
  Process: 1921 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
 Main PID: 1924 (code=exited, status=255)
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]:         :111 +0x6c
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]: (0xc42023f180, 0x1d46360, 0xc432c4d5c0, 0xc430737a50, 0x1, 0x1)
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]:         :87 +0x81
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]: (0xc432c39550, 0x1, 0x1, 0x0)
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]:         :1519 +0x106
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]: (0xc4208ec4e0, 0x1e178cf, 0xa, 0xc432c39550, 0x1, 0x1)
Feb 21 01:49:25 Airborne-Multigaming sinusbot[1924]:         :740 +0x14f
Feb 21 01:49:25 Airborne-Multigaming systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/n/a
Feb 21 01:49:25 Airborne-Multigaming systemd[1]: sinusbot.service: Unit entered failed state.
Feb 21 01:49:25 Airborne-Multigaming systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Ich hoffe ihr könnt mir helfen da wir stark darauf angewiesen sind.
Vielen Dank im Vorraus
könntest du bitte den vollen service log posten? journalctl -u sinusbot
AiR-Angelo
Sehr gerne ... Das ist alles was er mir da ausspuckt :
-- Logs begin at Thu 2019-02-21 01:39:19 CET, end at Thu 2019-02-21 18:05:04 CET
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: Starting Sinusbot, the Teamspea
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: Started Sinusbot, the Teamspeak
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]:  ___ ___ _  _ _   _ ___ ___
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: / __|_ _| \| | | | / __| _ )
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: \__ \| || .` | |_| \__ \ _ \
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: |___/___|_|\_|\___/|___/___/
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: Version: 1.0.0-alpha.5-97676
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: (C) 2013-2019 Michael Friese
Feb 21 01:39:26 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:26 9dea1526
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526
lines 1-23...skipping...
-- Logs begin at Thu 2019-02-21 01:39:19 CET, end at Thu 2019-02-21 18:05:04 CET. --
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set invocation ID on control group /system.slice/sinusbot.servi
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: Starting Sinusbot, the Teamspeak 3 and Discord music bot....
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: Started Sinusbot, the Teamspeak 3 and Discord music bot..
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]:  ___ ___ _  _ _   _ ___ ___  ___ _____
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: / __|_ _| \| | | | / __| _ )/ _ \_   _|
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: \__ \| || .` | |_| \__ \ _ \ (_) || |
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: |___/___|_|\_|\___/|___/___/\___/ |_|
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: Version: 1.0.0-alpha.5-9767656
Feb 21 01:39:23 Airborne-Multigaming sinusbot[197]: (C) 2013-2019 Michael Friese. All rights reserved.
Feb 21 01:39:26 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:26 9dea1526          INFO   Loading instances
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://d707a31c-b9bc-7453-331f-
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c WARN   script support-pp is requesting missing per
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   script OKlib loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   script command loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   script reconnect loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   Initialization complete
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://9c1868f5-761c-5f22-d1c5-
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 WARN   script support-pp is requesting missing per
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   script command loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   script OKlib loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   script liftchannel loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   script MessageToGroups_1_0 loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   script reconnect loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   Initialization complete
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://86a0b791-7f3c-6b05-8167-
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 WARN   script support-pp is requesting missing per
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   script command loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   script OKlib loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   script reconnect loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   script auto_channel_creator loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   script MessageToGroups_1_0 loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   Initialization complete
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://eeb95232-91ac-4dd3-a5ae-
lines 1-37...skipping...
Feb 21 01:39:21 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set invocation ID on control group /system.slice/sinusbot.service, ignoring: Operation not permitted
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://d707a31c-b9bc-7453-331f-405b61d6202a
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c WARN   script support-pp is requesting missing permission to use module db, disabled
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 d707a31c INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/d707a31c-b9bc-7453-331f-405b61d6202a in 500 ms...
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://9c1868f5-761c-5f22-d1c5-c6463dff421f
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 WARN   script support-pp is requesting missing permission to use module db, disabled
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 9c1868f5 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/9c1868f5-761c-5f22-d1c5-c6463dff421f in 1000 ms...
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://86a0b791-7f3c-6b05-8167-57dac218ec32
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 WARN   script support-pp is requesting missing permission to use module db, disabled
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 86a0b791 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/86a0b791-7f3c-6b05-8167-57dac218ec32 in 1500 ms...
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526          INFO   Loading instance://eeb95232-91ac-4dd3-a5ae-dd85048e0b4a
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   script OKlib loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   script command loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 config to store: {"msg_feedback_closeFeedbakSession":"Schade drum #Feedback geschlossen","msg_feedback_closeFeedbakSessionOk":"Wir sind dir sehr dankbar für dein Feed
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 88/]AiR Vegna[/URL][/size][/COLOR][/B]\n[B][COLOR=#0055ff][size=13][URL=http://steamcommunity.com/id/fluffymike305]AiR FluffyMike[/URL][/size][/COLOR][/B]\n[B][COLOR=#0055ff][size=13][UR
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: pio_MZ [/COLOR] [/B]\n[size=12][B]  [COLOR=#ff5500] MrP3w [/COLOR] [/B]\n\n\n\n[size=12][B][url=http://steamcommunity.com/groups/AirborneTarkov][COLOR=#00ffff]Escape From Tarkov Supporte
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: ClientsOnline":-1,"spSupportChannelNameChange":"7127","spSupportChannelNameOfflineDescription":"[center][size=20][COLOR=#ff0000][b]Unser Support ist von 11:00 bis 23:00 Uhr geöffnet. Auc
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: size=11][B][COLOR=#ff007f]AiR-Houston[/COLOR][/B][/size]\n[size=11][B][COLOR=#ff007f]AiR-Zerkzes[/COLOR][/B][/size]\n\n\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/si
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size]\n\n[size=12][B][U][COLOR=#8de457]The Division Supporter | Steam ID´s:[/COLOR][/U][/B][/size]\n\n[size=11][B][URL=http:
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 55ff][size=13][URL=https://steamcommunity.com/profiles/76561198139905217/][AiR] RocketJaxX[/URL][/size][/COLOR][/B]\n\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: lNameOfflineMsg":"> UNBESETZT ► ESCAPE FROM TARKOV ◄","spSupportChannelNameOnlinDescription":"[center]\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size]\n\n[size=12][
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 1981","spSupportChannelNameOfflineDescription":"[center][size=20][COLOR=#ff0000][b]Unser Support ist von 11:00 bis 23:00 Uhr geöffnet. Auch während dieser Zeit bitten wir um etwas Geduld
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]:  [COLOR=#870000] [U] Apex Legends Origin ID :[/U][/COLOR][/b]\n\n[size=11][B]   [COLOR=#870000] AiR-Nakedwildman[/COLOR]  [/B]\n[size=11][B]   [COLOR=#870000] AiR-Agy[/COLOR]  [/B]\n[siz
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: COLOR=#00ffff] AiR GigA[/COLOR][/URL][/B][/size]\n[size=11][B][URL=http://steamcommunity.com/profiles/76561198116611845/][COLOR=#00ffff]AiR BlackWolf[/COLOR][/URL][/B][/size]\n[size=11][
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: ocket League Supporter | Steam ID´s:[/url][/U][/COLOR][/B][/size]\n\n[B][COLOR=#0055ff][size=13][URL=http://steamcommunity.com/profiles/76561197996328111/]AiR iosis[/URL][/size][/COLOR][
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: OLOR=#e9e900]AiR-Bauli[/COLOR][/B][/size]\n[size=11][B][U][COLOR=#e9e900]AiR-Taker[/COLOR][/B][/size]\n[size=11][B][U][COLOR=#e9e900]Satellite.AiR[/COLOR][/B][/size]\n[size=11][B][U][COL
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: [U] Call of Duty: BO 4 Supporter | Battletag:[/U][/COLOR][/b]\n\n[size=12][B]   [COLOR=#ff5500] DerAlphabet#2706 [/COLOR]  [/B]","spSupportChannelNameOnlineMsg":"▼▼▼","spSupportChannelPa
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: ize=12][B]   [COLOR=#00aa00] SmokZ ► AiR IForgetZ [/COLOR]  [/B]\n[size=12][B]   [COLOR=#00aa00] Tobi ► AiR St0rmw1nd [/COLOR]  [/B]\n\n[size=15][b][img]http://puu.sh/tjVMl/6fa809212c/gi
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: Feedback":"","spPrefixSupport":"►","spPrefixTicket":"","spPrefixTicketReplay":"","spSupportChannelCloseAutomatic":true,"spSupportChannelCommandClose":"!off","spSupportChannelCommandOpen"
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: n. Bitte warte hier, Supporter wurden informiert.","spSupporterId":["416","417"]},{"spSupportChannel":"9108","spSupportMessage":"Ein Gast ist im [b]COD Support[/b]","spSupportUserMessage
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: fix":"sup"},{"spTime":"12:00","spTimeAction":"0","spTimePrefix":"sup"},{"spTime":"23:59","spTimeAction":"1","spTimePrefix":"sup2"},{"spTime":"12:00","spTimeAction":"0","spTimePrefix":"su
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 PLUGIN connecting to db: support_Angelo:xxxxxx@tcp(db.support-pp.de:3306)/support_Angelo
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 PLUGIN [      support-pp:3047:16] [Support++] Create new DB if not exist...
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 PLUGIN [      support-pp:3042:57] [Support++] DB connection OK!
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   script support-pp loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   script PrivatChannelManager 2.0.4 (Angelo edit) loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   script reconnect loaded
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   Initialization complete
Feb 21 01:39:28 Airborne-Multigaming sinusbot[197]: 2019/02/21 01:39:28 9dea1526 eeb95232 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/eeb95232-91ac-4dd3-a5ae-dd85048e0b4a in 2000 ms...
root@Airborne-Multigaming:~# systemctl start sinusbot
Job for sinusbot.service failed because the control process exited with error code.
See "systemctl status sinusbot.service" and "journalctl -xe" for details.
root@Airborne-Multigaming:~# journalctl -u sinusbot
-- Logs begin at Thu 2019-02-21 01:39:19 CET, end at Thu 2019-02-21 18:07:22 CET. --
Da sind aber nicht mehr die zeilen dabei die du da letzthin hattest wäre von vorteil wenn der absturz mit dabei ist
AiR-Angelo
-- Logs begin at Thu 2019-02-21 19:25:47 CET, end at Thu 2019-02-21 19:31:08 CET
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: Starting Sinusbot, the Teamspea
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: Started Sinusbot, the Teamspeak
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]:  ___ ___ _  _ _   _ ___ ___
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: / __|_ _| \| | | | / __| _ )
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: \__ \| || .` | |_| \__ \ _ \
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: |___/___|_|\_|\___/|___/___/
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: Version: 1.0.0-alpha.5-97676
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: (C) 2013-2019 Michael Friese
Feb 21 19:25:52 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:52 9dea1526
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526
-- Logs begin at Thu 2019-02-21 19:25:47 CET, end at Thu 2019-02-21 19:31:08 CET. --
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set invocation ID on control group /system.slice/sinusbot.service, ignoring: Operation n
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: Starting Sinusbot, the Teamspeak 3 and Discord music bot....
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: Started Sinusbot, the Teamspeak 3 and Discord music bot..
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]:  ___ ___ _  _ _   _ ___ ___  ___ _____
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: / __|_ _| \| | | | / __| _ )/ _ \_   _|
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: \__ \| || .` | |_| \__ \ _ \ (_) || |
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: |___/___|_|\_|\___/|___/___/\___/ |_|
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: Version: 1.0.0-alpha.5-9767656
Feb 21 19:25:50 Airborne-Multigaming sinusbot[206]: (C) 2013-2019 Michael Friese. All rights reserved.
Feb 21 19:25:52 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:52 9dea1526          INFO   Loading instances
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526          INFO   Loading instance://9c1868f5-761c-5f22-d1c5-c6463dff421f
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 WARN   script support-pp is requesting missing permission to use module db,
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   script command loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   script OKlib loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   script liftchannel loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   script reconnect loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   script MessageToGroups_1_0 loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   Initialization complete
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/9c1868f5-761c-5f2
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526          INFO   Loading instance://86a0b791-7f3c-6b05-8167-57dac218ec32
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 WARN   script support-pp is requesting missing permission to use module db,
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   script command loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   script OKlib loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   script reconnect loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   script MessageToGroups_1_0 loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   script auto_channel_creator loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   Initialization complete
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/86a0b791-7f3c-6b0
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526          INFO   Loading instance://eeb95232-91ac-4dd3-a5ae-dd85048e0b4a
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   script command loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   script OKlib loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   script reconnect loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 config to store: {"msg_feedback_closeFeedbakSession":"Schade drum #Feedback geschlossen","msg
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 88/]AiR Vegna[/URL][/size][/COLOR][/B]\n[B][COLOR=#0055ff][size=13][URL=http://steamcommunity.com/id/fluffymike30
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: pio_MZ [/COLOR] [/B]\n[size=12][B]  [COLOR=#ff5500] MrP3w [/COLOR] [/B]\n\n\n\n[size=12][B][url=http://steamcommu
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: ClientsOnline":-1,"spSupportChannelNameChange":"7127","spSupportChannelNameOfflineDescription":"[center][size=20]
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: size=11][B][COLOR=#ff007f]AiR-Houston[/COLOR][/B][/size]\n[size=11][B][COLOR=#ff007f]AiR-Zerkzes[/COLOR][/B][/siz
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size]\n\n[size=12][B][U][COLOR=#8de457]The Division
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 55ff][size=13][URL=https://steamcommunity.com/profiles/76561198139905217/][AiR] RocketJaxX[/URL][/size][/COLOR][/
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: lNameOfflineMsg":"> UNBESETZT ► ESCAPE FROM TARKOV ◄","spSupportChannelNameOnlinDescription":"[center]\n[size=12]
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 1981","spSupportChannelNameOfflineDescription":"[center][size=20][COLOR=#ff0000][b]Unser Support ist von 11:00 bi
lines 1-42...skipping...
Feb 21 19:25:48 Airborne-Multigaming systemd[1]: sinusbot.service: Failed to set invocation ID on control group /system.slice/sinusbot.service, ignoring: Operation not permitted
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 WARN   script support-pp is requesting missing permission to use module db, disabled
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 9c1868f5 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/9c1868f5-761c-5f22-d1c5-c6463dff421f in 500 ms...
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 WARN   script support-pp is requesting missing permission to use module db, disabled
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 86a0b791 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/86a0b791-7f3c-6b05-8167-57dac218ec32 in 1000 ms...
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 config to store: {"msg_feedback_closeFeedbakSession":"Schade drum #Feedback geschlossen","msg_feedback_closeFeedbakSessionOk":"Wir sind dir sehr dankbar für dein Feed
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 88/]AiR Vegna[/URL][/size][/COLOR][/B]\n[B][COLOR=#0055ff][size=13][URL=http://steamcommunity.com/id/fluffymike305]AiR FluffyMike[/URL][/size][/COLOR][/B]\n[B][COLOR=#0055ff][size=13][UR
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: pio_MZ [/COLOR] [/B]\n[size=12][B]  [COLOR=#ff5500] MrP3w [/COLOR] [/B]\n\n\n\n[size=12][B][url=http://steamcommunity.com/groups/AirborneTarkov][COLOR=#00ffff]Escape From Tarkov Supporte
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: ClientsOnline":-1,"spSupportChannelNameChange":"7127","spSupportChannelNameOfflineDescription":"[center][size=20][COLOR=#ff0000][b]Unser Support ist von 11:00 bis 23:00 Uhr geöffnet. Auc
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: size=11][B][COLOR=#ff007f]AiR-Houston[/COLOR][/B][/size]\n[size=11][B][COLOR=#ff007f]AiR-Zerkzes[/COLOR][/B][/size]\n\n\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/si
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size]\n\n[size=12][B][U][COLOR=#8de457]The Division Supporter | Steam ID´s:[/COLOR][/U][/B][/size]\n\n[size=11][B][URL=http:
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 55ff][size=13][URL=https://steamcommunity.com/profiles/76561198139905217/][AiR] RocketJaxX[/URL][/size][/COLOR][/B]\n\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: lNameOfflineMsg":"> UNBESETZT ► ESCAPE FROM TARKOV ◄","spSupportChannelNameOnlinDescription":"[center]\n[size=12][b][img]http://puu.sh/tjVMl/6fa809212c/gif[/img][/b][/size]\n\n[size=12][
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 1981","spSupportChannelNameOfflineDescription":"[center][size=20][COLOR=#ff0000][b]Unser Support ist von 11:00 bis 23:00 Uhr geöffnet. Auch während dieser Zeit bitten wir um etwas Geduld
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]:  [COLOR=#870000] [U] Apex Legends Origin ID :[/U][/COLOR][/b]\n\n[size=11][B]   [COLOR=#870000] AiR-Nakedwildman[/COLOR]  [/B]\n[size=11][B]   [COLOR=#870000] AiR-Agy[/COLOR]  [/B]\n[siz
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: COLOR=#00ffff] AiR GigA[/COLOR][/URL][/B][/size]\n[size=11][B][URL=http://steamcommunity.com/profiles/76561198116611845/][COLOR=#00ffff]AiR BlackWolf[/COLOR][/URL][/B][/size]\n[size=11][
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: ocket League Supporter | Steam ID´s:[/url][/U][/COLOR][/B][/size]\n\n[B][COLOR=#0055ff][size=13][URL=http://steamcommunity.com/profiles/76561197996328111/]AiR iosis[/URL][/size][/COLOR][
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: OLOR=#e9e900]AiR-Bauli[/COLOR][/B][/size]\n[size=11][B][U][COLOR=#e9e900]AiR-Taker[/COLOR][/B][/size]\n[size=11][B][U][COLOR=#e9e900]Satellite.AiR[/COLOR][/B][/size]\n[size=11][B][U][COL
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: [U] Call of Duty: BO 4 Supporter | Battletag:[/U][/COLOR][/b]\n\n[size=12][B]   [COLOR=#ff5500] DerAlphabet#2706 [/COLOR]  [/B]","spSupportChannelNameOnlineMsg":"▼▼▼","spSupportChannelPa
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: ize=12][B]   [COLOR=#00aa00] SmokZ ► AiR IForgetZ [/COLOR]  [/B]\n[size=12][B]   [COLOR=#00aa00] Tobi ► AiR St0rmw1nd [/COLOR]  [/B]\n\n[size=15][b][img]http://puu.sh/tjVMl/6fa809212c/gi
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: Feedback":"","spPrefixSupport":"►","spPrefixTicket":"","spPrefixTicketReplay":"","spSupportChannelCloseAutomatic":true,"spSupportChannelCommandClose":"!off","spSupportChannelCommandOpen"
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: n. Bitte warte hier, Supporter wurden informiert.","spSupporterId":["416","417"]},{"spSupportChannel":"9108","spSupportMessage":"Ein Gast ist im [b]COD Support[/b]","spSupportUserMessage
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: fix":"sup"},{"spTime":"12:00","spTimeAction":"0","spTimePrefix":"sup"},{"spTime":"23:59","spTimeAction":"1","spTimePrefix":"sup2"},{"spTime":"12:00","spTimeAction":"0","spTimePrefix":"su
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 PLUGIN connecting to db: support_Angelo:xxxxxx@tcp(db.support-pp.de:3306)/support_Angelo
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 PLUGIN [      support-pp:3047:16] [Support++] Create new DB if not exist...
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 PLUGIN [      support-pp:3042:57] [Support++] DB connection OK!
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   script support-pp loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   script PrivatChannelManager 2.0.4 (Angelo edit) loaded
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   Initialization complete
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 INFO   Auto-Starting 9dea1526-66bf-4be0-a621-cdc54c98ef39/eeb95232-91ac-4dd3-a5ae-dd85048e0b4a in 1500 ms...
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: 2019/02/21 19:25:54 9dea1526 eeb95232 PLUGIN error on callback func: Uncaught exception: Error: the command should match the following pattern '/^[a-z0-9_-]+$/i'
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: at command:618:48
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]:               if (!(/^[a-z0-9_-]+$/i).test(name)) throw new Error("the command should match the following pattern '/^[a-z0-9_-]+$/i'")
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]:                                                   ^
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]: Stack trace: Error: the command should match the following pattern '/^[a-z0-9_-]+$/i'
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]:     at Function.validateCommandName (command:618:55)
Feb 21 19:25:54 Airborne-Multigaming sinusbot[206]:     at Object.createCommand (command:1290:26)
das wirft er mir raus
gesucht werden diese zeilen:
AiR-Angelo
ja ich weis nicht mehr wirft er mir nicht raus
mehr wird nicht geladen wenn ich den von dir gesendeten Command eingebe
AiR-Angelo
Leider besteht das Problem immernoch habe es nochmals versucht alles neu zu installieren und es bleibt mir dieser Fehler output
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0xc42000e028, 0xc420ab81f8,
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]:         :181 +0x70
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0x7f5d98ec16e0, 0xc42000e02
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]:         :307 +0xa9
Feb 25 18:06:56 Airborne-Multigaming systemd[1]: sinusbot.service: Main process
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: State 'stop-s
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Killing proce
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Unit entered
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Failed with r
lines 1-18/18 (END)...skipping...
   Active: failed (Result: exit-code) since Mon 2019-02-25 18:08:26 CET; 31s ago
  Process: 1162 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
  Process: 211 ExecStart=/opt/sinusbot/sinusbot (code=exited, status=255)
  Process: 203 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
 Main PID: 211 (code=exited, status=255)
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0xc42000e028, 0xc420ab81f8, 0x4, 0x4, 0x0, 0x0, 0x0)
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0x7f5d98ec16e0, 0xc42000e028, 0xc420ab81f8, 0x4, 0x4, 0x4, 0x1ded
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0x7f5d98ec16e0, 0xc42000e028, 0xc420ab81f8, 0x4, 0x4, 0x0, 0x0, 0
Feb 25 18:06:56 Airborne-Multigaming systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/n/a
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: State 'stop-sigterm' timed out. Killing.
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Killing process 812 (ts3client_linux) with signal S
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Unit entered failed state.
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0x7f5d98ec16e0, 0xc42000e028, 0xc420ab81f8, 0x4, 0x4, 0x4, 0x1dedc20, 0x0, 0x7f5d98ec16e0)
Feb 25 18:06:56 Airborne-Multigaming sinusbot[211]: (0x7f5d98ec16e0, 0xc42000e028, 0xc420ab81f8, 0x4, 0x4, 0x0, 0x0, 0x5c0000)
Feb 25 18:08:26 Airborne-Multigaming systemd[1]: sinusbot.service: Killing process 812 (ts3client_linux) with signal SIGKILL.
Ich glaube ich habe ein ähnliches Phänomen, ich habe die 5 Bots online, und sobald ich den 6. dazu schalte, schmiert alles ab, inkl. Webinterface.
Konnte es auch schonmal umschiffen, starten ohne gewisse Skripte, und nach einer Zeit habe ich die wieder aktiviert.
Hier die gesuchten Zeilen des letzten Crashes:
Feb 25 19:22:12 c1292006 sinusbot[86212]:         :111 +0x6c
Feb 25 19:22:12 c1292006 sinusbot[86212]: (0xc42ae817c0, 0x1d46360, 0xc420eff110, 0xc4211a66a8, 0x1, 0x1)
Feb 25 19:22:12 c1292006 sinusbot[86212]:         :87 +0x81
Feb 25 19:22:12 c1292006 sinusbot[86212]: (0xc42ea814d0, 0x1, 0x1, 0x0)
Feb 25 19:22:12 c1292006 sinusbot[86212]:         :1519 +0x106
Feb 25 19:22:12 c1292006 sinusbot[86212]: (0xc42ae2eae0, 0x1e178cf, 0xa, 0xc42ea814d0, 0x1, 0x1)
Feb 25 19:22:12 c1292006 sinusbot[86212]:         :740 +0x14f
Feb 25 19:22:12 c1292006 sinusbot[86212]: ()
Feb 25 19:22:12 c1292006 sinusbot[86212]:         :2197 +0x1
Feb 25 19:22:12 c1292006 systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/n/a
Feb 25 19:22:13 c1292006 systemd[1]: sinusbot.service: Unit entered failed state.
Feb 25 19:22:13 c1292006 systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Und hier ein nochmals forcierter Crash:
Feb 25 21:35:05 c1292006 sinusbot[92563]:         :111 +0x6c
Feb 25 21:35:05 c1292006 sinusbot[92563]: (0xc420397640, 0x1d46360, 0xc420edc060, 0xc4300bee08, 0x1, 0x1)
Feb 25 21:35:05 c1292006 sinusbot[92563]:         :87 +0x81
Feb 25 21:35:05 c1292006 sinusbot[92563]: (0xc42fc04d70, 0x1, 0x1, 0x0)
Feb 25 21:35:05 c1292006 sinusbot[92563]:         :1519 +0x106
Feb 25 21:35:05 c1292006 sinusbot[92563]: (0xc4202e68a0, 0x1e178cf, 0xa, 0xc42fc04d70, 0x1, 0x1)
Feb 25 21:35:05 c1292006 sinusbot[92563]:         :740 +0x14f
Feb 25 21:35:05 c1292006 sinusbot[92563]: ()
Feb 25 21:35:05 c1292006 sinusbot[92563]:         :2197 +0x1
Feb 25 21:35:05 c1292006 systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/n/a
Feb 25 21:35:05 c1292006 systemd[1]: sinusbot.service: Unit entered failed state.
Feb 25 21:35:05 c1292006 systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Wie flyth schon in einem anderen Thread erwähnt hatte werden die ersten paar Zeilen des Errors benötigt nicht nur der letzte Teil
journalctl -u sinusbot.service
