MTU = 1500
LicenseKey = "Mylicense"
DisableLocalXServer = false
DebugLocalXServer = false
2015/12/29 08:12:26 664c4334 9e58808f WARN Could not send join command
2015/12/29 08:12:28 664c4334 eace2920 WARN Could not send var command
2015/12/29 08:12:28 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=3)
2015/12/29 08:12:28 664c4334 eace2920 WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/29 08:12:28 664c4334 9e58808f WARN Could not send var command
2015/12/29 08:12:28 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=3)
2015/12/29 08:12:28 664c4334 9e58808f WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not send var command
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=4)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=5)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=6)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=7)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=8)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=9)
2015/12/29 08:12:33 664c4334 eace2920 WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not send var command
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=4)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=5)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=6)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=7)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=8)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=9)
2015/12/29 08:12:33 664c4334 9e58808f WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not send var command
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=10)
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=11)
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=12)
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not find request%!(EXTRA uint32=13)
2015/12/29 08:12:38 664c4334 eace2920 WARN Could not send config. Please make sure that the loopback interface is not firewalled and the plugin is installed properly.
2015/12/29 08:12:38 664c4334 9e58808f WARN Could not send var command
2015/12/29 08:12:38 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=10)
2015/12/29 08:12:38 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=11)
2015/12/29 08:12:38 664c4334 9e58808f WARN Could not find request%!(EXTRA uint32=12)
2015/12/29 08:12:40 664c4334 eace2920 DEBUG Storing configuration.
2015/12/29 08:12:41 664c4334 9e58808f DEBUG Storing configuration.
2015/12/29 08:13:20 664c4334 9e58808f INFO TS |INFO |ClientUI |1 |Ignored text message by Billboard: Now playing: Macklemore - Ryan Lewis - Eric Nally - Melle Me - Kool Moe Dee - Grandmaster Caz) - Downtown
2015/12/29 08:14:38 664c4334 eace2920 INFO TS |INFO |ClientUI |1 |Ignored text message by Hit Radio: Now playing: Sheppard - Geronimo
2015/12/29 08:18:07 664c4334 eace2920 INFO TS |INFO |ClientUI |1 |Ignored text message by Hit Radio: Now playing: Targetspot - TargetSpot
2015/12/29 08:18:11 664c4334 9e58808f INFO TS |INFO |ClientUI |1 |Ignored text message by Billboard: Now playing: Targetspot - TargetSpot
You put this https://forum.sinusbot.com/resources/digital-clock.29/download?version=116 file in you script folder and restarted?@Am4n the default script works perfectly but when i add like for example digitalclock.js in the folder, i reboot the bot and when i check webinterface i don't find the new one
root@debian:/opt/ts3soundboard/scripts# ls
advertising.js covatar.js idle.js showcase.js
aloneMode.js dev.js metadata.js Sound_on_Join.js
badchan.js digitalclock.js norecording.js welcometext.js
bookmark.js followme.js rememberChannel.js
- Operating System: Debian GNU/Linux 7.8 (wheezy)
- Kernel: Linux 3.2.0-4-amd64 x86_64
- Load Average: 0.55 0.57 0.59
- Uptime: 0 days, 10 hours, 35 minutes, 44 seconds
- OS Updates: 82 (updates available!)
- OS APT Last Update: 29.12.2015 07:56:57 CET +01:00:00
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 4
CPU MHz: 2133.409
Hypervisor vendor: VMware
Virtualization type: full
- RAM: 283.46 MB/9.79 GB in use (2%)
- SWAP: 0 B/8.13 GB in use (0%)
- DISK: 15.82 GB/163.44 GB in use (9%)
- Report date: 29.12.2015 10:28:46 CET +01:00:00 (timezone: Europe/Madrid)
- Status: running (PIDs: 4241 4240, User: root)
- Binary: /opt/ts3soundboard/sinusbot (Hash: 634662b72e5a6efc5ab92967bc8f3ace)
- Version: 0.9.9-8f70ff3
- Bot Plugin: 28511bf58fe820d911609f7252594400
- TS3 Client: 28511bf58fe820d911609f7252594400
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2015.12.23)
- Installed Scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; digitalclock.js; followme.js; idle.js; metadata.js; norecording.js; rememberChannel.js; showcase.js; Sound_on_Join.js; welcometext.js
