Script not appearing (Digitalclock.js)
LukBoy99
I added the script to my script folder, restarted, even did chown -R again for everything to make sure, it loads but doesn't appear as you can see here it loaded.But don't appear in my web interface.
Am4n
Does it only happen with this script or with others too?
LukBoy99
Only with this script, default scripts work fine, however, that script has been working for others and I contacted it's author he said it works, I gave permissions, restarted, enabled hot reload and restarted my whole vps, nothing worked.
