EN [Script Request] Assign servergroups by command!
Hello Sinusbot community!
I've been looking for a simple script that allows servergroups to request for a group by chat command.
Example;
User: assign nopoke
User was added to servergroup "no poke" by assign bot"
Their is already a script in .php that is exacly what i'm looking for.
http://forum.teamspeak.com/threads/117775-Server-Group-Assign-Bot
Hopefully someone can help me out. Would be awesome!
(You can also contact me private if you know how to get this script running on windows server 2012 r2)
-Greetings Smiling2death
Floflobel
Huum, the script is use for applying multi group.
The command is generic (set in setting) : !addgroup [id] and !rmgroup [id]
In setting :
Comma Seperated List of Group IDs wich may be affected :
14
The command, which should be used to assign the group :
!addgroup
The command, which should be used to remove the group :
!rmgroup
Limit the number of group :
1
Try to mp the bot : "!addgroup 14" and "!rmgroup 14"
In setting :
14
!addgroup
!rmgroup
1
Oh i see it's working now!
You have to add a command like "!addgroup" and "!delgroup" And add the number of the group "ID"
Working perfect thanks @Floflobel
Floflobel
Nice, tell me if you find a bug.
Feature list :
- Returns a message when adding or deleting a group
- Returns errors in messages instead of logs
- Restricting use of the command according to a server group
- Add group with name or with ID
- Add file of log when user add a group
Can anyone help me? This script don't work on my sinusbot. Logs:
2018/02/16 11:04:14 ff3c1f15 8f07caf4 INFO   PRIVATE-CHAT [Bartek200219] !addgroup 51
2018/02/16 11:04:14 ff3c1f15 8f07caf4 INFO   CHAT 1 [bartek @ Bartek200219] < !addgroup 51 > / NOTFOUND/NOPRIV
