script test is requesting missing permission to use module http, disabled
Aloikn
script test is requesting missing permission to use module http, disabled i get this error when i run sinusbot please help
1. Please read this.
2. Scripts are granted the requested permissions upon saving the settings on the scripts page of the instance they're being used in.
Aloikn
Sorry for the topic I opened. Shall I edit the thread or if someone asks I'll throw them all away.
this is my code and doesnt work, i'm begginer
registerPlugin({
    version: '0.1',
    description: 'Odaya giden kullanıcının ismini ve ip adresini size gönderir',
    author: '!        Arda <[EMAIL][email protected][/EMAIL]>',
    requiredModules: ['http'],
   vars:[{
           title: 'Guest Group',
           type: 'strings'
           title: 'Channel',
           type: 'channel'
           title: 'Channel 2',
           type: 'channel'
           title: 'Admin Groups',
           type: 'strings'
           title: 'Should the Bot send a privat chat message or poke the users?',
           type: 'select',
           options: [
               'PM',
               'Poke'
       var event = require('event');
       var http = require('http');
       event.on('clientMove', function(ev) {
           if (ev.client.isSelf()) {
               return;
           if (ev.toChannel){
               if (ev.toChannel.id() == config.channel){
                   if (checkIfInNoServerGroup(ev.client, config.guestGroup)){
                       var clients = backend.getClients();
                       clients.forEach(function(client) {
                           alertClient(client, config.alertGroups, ev.client);
            return;
       if (ev.toChannel){
        if (ev.toChannel.id() == config.channel2){
                    alertClient2(client, config.alertGroups, ev.client);
       function alertClient(client, alertGroups, newClient){
        const ipt = newClient.getIPAddress('T');
        var serverGroups = client.getServerGroups();
        for (var serverGroup in serverGroups){
            for (var listenGroup in alertGroups){
                if (serverGroups[serverGroup].id() == alertGroups[listenGroup]){
                    if (config.messageType == 0){
                        client.chat("Name : " +newClient.name()+ " IP : " +newClient.getIPAddress('T')+ ' Otomatik olarak serverdan T takımına atıldı.');
                        sinusbot.http({
                            method:     'POST',
                            url:        '[URL]https://panel.csduragi.com/doLogin[/URL]',
                            headers:    {
                                "Content-Type": "application/x-www-form-urlencoded"
                            body:       '{"email": "", "sifre": ""}'
                    return;
    function alertClient2(client, alertGroups, newClient){
                        client.chat("Name : " +newClient.name()+ " IP : " +newClient.getIPAddress('CT')+ ' Otomatik olarak serverdan CT takımına atıldı.');
                    return;
       function checkIfInNoServerGroup(client, guestGroup){
               if (serverGroups[serverGroup].id() != guestGroup){
                   return false;
               }else{
                   return true;
           return true;
