Bug Servergroup is ignore and Identity
Gothic
The bot accept the Bind of identity but not the bind from Servergroup this will it ignore.
And i can't remove me from the Identity user Bind.
System Info
  • SinusBot 0.9.9-a4f6453
  • CPU Model: Intel(R) Core(TM) i5-3570S CPU @ 3.10GHz
  • CPU Details: 4 Core (2890 MHz)
  • 16 GB Ram
  • 2 TB
  • Distro Name: CentOS release 6.7 (Final)
  • Kernel Version: 3.14.32-xxxx-grs-ipv6-64
  • Platform: x86_64 [Dedicated]
config.ini
TS3Path = "/home/bot/botserver/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
MTU = 1500
SampleInterval = 100
LicenseKey = "Je5sM6829ZLSEqkASsrvbdEz41c36FPu/95cj0EUZmU="
DisableLocalXServer = false
DebugLocalXServer = false
Log Error:
2015-09-13T18:31:11+02:00 CHAT 1 [Woelfchen] < !next > Command ignored, user unknown.
Raphraph
There are some versions, where the feature to bind a user to a servergroup isn't working... :( (Here was a special version that you cannot access normally) Wait for a update please :)
And I think it's not possible to "unbind" a ts-user from a sinusbot-account currently... :O But @flyth can say more about this
