simple_channel_creator erstellt keine Channel mehr
Nicole Sophie
Moin Moin
Würde mich sehr über hilfe freuen.
Ich habe mal wieder das Problem das "simple_channel_creator" keine channel mehr erstellt.
Habe deswegen schon den kommpletten Serverneu gestartet ohne erfolg.
Dazu muß ich gleich am anfang mit sagen damit der Bot volle ServerAdmin rechte hat.
Und das hier steht in der Log drinne
2021-06-11T19:55:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:54:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:53:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:52:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:51:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:50:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:49:29+02:00 error on setTimeout/setInterval callback: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:27 var ds = store.get(key); ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:2658:28 at Array.forEach (<anonymous>) at Support:2657:25
2021-06-11T19:48:33+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2021-06-11T19:48:33+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2021-06-11T19:48:33+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2021-06-11T19:48:33+02:00 error on callback func: Uncaught exception: Error: Panic during callback "On": runtime error: invalid memory address or nil pointer dereference at simple_channel_creator:103:10 event.on('clientVisible', function (moveInfo) { ^ Stack trace: Error: Panic during callback "On": runtime error: invalid memory address or nil pointer dereference at simple_channel_creator:103:11
2021-06-11T19:48:33+02:00 New connection status 4; Error 0
2021-06-11T19:48:33+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2021-06-11T19:48:33+02:00 New connection status 3; Error 0
2021-06-11T19:48:33+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2021-06-11T19:48:33+02:00 New connection status 2; Error 0
2021-06-11T19:48:33+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2021-06-11T19:48:33+02:00 New connection status 1; Error 0
2021-06-11T19:48:33+02:00 TS |DEVELOP |PktHandler |1 |Puzzle solve time: 2
2021-06-11T19:48:33+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=Support&password=&cid=578&channelpassword=
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/ecf2b8e9-98d7-4d5b-8cc5-732db70bad44/4ce3c793-46bb-afd2-9dc5-94990df22d57/settings.db
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2021-06-11T19:48:32+02:00 TS |INFO | | |*** Time [INIT]: 201
2021-06-11T19:48:32+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 201
2021-06-11T19:48:32+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2021-06-11T19:48:32+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2021-06-11T19:48:32+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2021-06-11T19:48:32+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2021-06-11T19:48:32+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2021-06-11T19:48:32+02:00 TS |INFO |Addons | |Checking for addon updates...
2021-06-11T19:48:32+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2021-06-11T19:48:32+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2021-06-11T19:48:32+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2021-06-11T19:48:32+02:00 TS |INFO | | |Using hardware aes
2021-06-11T19:48:32+02:00 TS |INFO | | |SystemInformation: Linux 4.19.0-16-amd64 #1 SMP Debian 4.19.181-1 (2021-03-19) x86_64 Binary: 64bit
2021-06-11T19:48:32+02:00 TS |INFO | | |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
2021-06-11T19:48:31+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Support&password=&cid=578&channelpassword=
2021-06-11T19:48:31+02:00 Could not create Notifications-Tabletable Notifications already exists
2021-06-11T19:48:31+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2021-06-11T19:48:31+02:00 Could not create Chat-Tabletable Chat already exists
2021-06-11T19:48:29+02:00 failed to run: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:4044:18 if (store.get("newsletter-mail") != "") { ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:4044:19
2021-06-11T19:48:29+02:00 error running script: Uncaught exception: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:4044:18 if (store.get("newsletter-mail") != "") { ^ Stack trace: Error: Panic during callback "Get": runtime error: invalid memory address or nil pointer dereference at Support:4044:19
2021-06-11T19:48:29+02:00 Auto-Starting ecf2b8e9-98d7-4d5b-8cc5-732db70bad44/4ce3c793-46bb-afd2-9dc5-94990df22d57 in 2000 ms...
2021-06-11T19:48:29+02:00 Initialization complete
2021-06-11T19:48:29+02:00 script simple_channel_creator loaded
2021-06-11T19:48:29+02:00 script sinusbot-commands loaded
2021-06-11T19:48:29+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2021-06-11T19:48:29+02:00 script command loaded
Nicole Sophie
Irgend wie reagiert der bot jetzt garnicht mehr. noch nicht mal mehr auf chat befehle das er gewisse channel öffnen soll und schließen soll.
Nicole Sophie
Kaum Sinusbot neu installiert geht der mist von vorne los.
Bitte helft mir ich bin am verzweifeln.
2021-06-17T20:33:59+02:00 error on callback func: Uncaught exception: TypeError: Cannot read property 'name' of undefined at Support:3597:82 if (backend.getChannelByID(channelEdit.spSupportChannelNameChange).name() == channelEdit.spSupportChannelNameOfflineMsg) { ^ Stack trace: TypeError: Cannot read property 'name' of undefined at Support:3597:83 at Array.forEach (<anonymous>) at closeSupportChannel (Support:3587:30) at Support:3507:21 at Array.forEach (<anonymous>) at Support:3506:38
2021-06-17T20:33:47+02:00 error on callback func: Uncaught exception: TypeError: Cannot read property 'name' of undefined at Support:3658:82 if (backend.getChannelByID(channelEdit.spSupportChannelNameChange).name() == channelEdit.spSupportChannelNameOnlineMsg) { ^ Stack trace: TypeError: Cannot read property 'name' of undefined at Support:3658:83 at Array.forEach (<anonymous>) at openSupportChannel (Support:3649:30) at Support:3484:21 at Array.forEach (<anonymous>) at Support:3483:38
2021-06-17T20:32:48+02:00 [simple_channel_creator:154:28] [{"id":"80","name":"[cspacer]⮞⮞⮞ ATS ⮜⮜⮜","config":{"parent":"80","prefix":"Unterwegs in America","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"password":"","topic":"","description":"","talkPower":0},"children":[{}]},{"id":"309","name":"RTT Gästebereich","config":{"parent":"309","prefix":"RTT Gästelounge","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":0,"talkPower":0,"password":"","topic":"","description":""},"children":[{}]},{"id":"109","name":"╔--LS19/17/15","config":{"parent":"109","prefix":"Bauernhof","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{},{}]},{"id":"328","name":"LifeStream Fahrer","config":{"parent":"328","prefix":"LifeStream (Achtung! mit Ton)","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","description":"!! ACHTUNG !!\n\nHier wird mit TS aufgezeichnet.","joinPower":10,"password":"","topic":"","talkPower":0},"children":[{}]},{"id":"75","name":"[cspacer]⮞⮞⮞ ETS ⮜⮜⮜","config":{"parent":"75","prefix":"Unterwegs in ETS2","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{}]},{"id":"310","name":"RTT Fahrer Laberecke","config":{"parent":"310","prefix":"RTT Laberecke","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{},{}]},{"id":"43","name":"[cspacer]Supportbereich","config":{"parent":"43","prefix":"Support","minChannels":1,"maxClients":4,"codec":"4","codecQuality":"5","description":"","joinPower":35,"talkPower":0,"password":"","topic":""},"children":[{}]},{"id":"332","name":"LifeStream RTT Twitcher-in/Youtuber-in","config":{"description":"!! ACHTUNG !!\n\nHier wird mit TS aufgezeichnet.\n\n!! ACHTUNG !!\n\nNur nach Aufforderung betretten. Sonst Kick vom Server.","parent":"332","prefix":"LifeStream RTT Twitcher-in/Youtuber-in","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":25,"talkPower":0,"password":"","topic":""},"children":[{}]}]
2021-06-17T20:32:48+02:00 [simple_channel_creator:153:28] 2341
2021-06-17T20:32:48+02:00 [simple_channel_creator:152:28] === Size of JSON.stringify(parentChannels):
2021-06-17T20:32:45+02:00 [simple_channel_creator:154:28] [{"id":"80","name":"[cspacer]⮞⮞⮞ ATS ⮜⮜⮜","config":{"parent":"80","prefix":"Unterwegs in America","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"password":"","topic":"","description":"","talkPower":0},"children":[{}]},{"id":"309","name":"RTT Gästebereich","config":{"parent":"309","prefix":"RTT Gästelounge","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":0,"talkPower":0,"password":"","topic":"","description":""},"children":[{}]},{"id":"109","name":"╔--LS19/17/15","config":{"parent":"109","prefix":"Bauernhof","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{},{}]},{"id":"328","name":"LifeStream Fahrer","config":{"parent":"328","prefix":"LifeStream (Achtung! mit Ton)","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","description":"!! ACHTUNG !!\n\nHier wird mit TS aufgezeichnet.","joinPower":10,"password":"","topic":"","talkPower":0},"children":[{}]},{"id":"75","name":"[cspacer]⮞⮞⮞ ETS ⮜⮜⮜","config":{"parent":"75","prefix":"Unterwegs in ETS2","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{}]},{"id":"310","name":"RTT Fahrer Laberecke","config":{"parent":"310","prefix":"RTT Laberecke","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":10,"talkPower":0,"password":"","topic":"","description":""},"children":[{},{}]},{"id":"43","name":"[cspacer]Supportbereich","config":{"parent":"43","prefix":"Support","minChannels":1,"maxClients":4,"codec":"4","codecQuality":"5","description":"","joinPower":35,"talkPower":0,"password":"","topic":""},"children":[{}]},{"id":"332","name":"LifeStream RTT Twitcher-in/Youtuber-in","config":{"description":"!! ACHTUNG !!\n\nHier wird mit TS aufgezeichnet.\n\n!! ACHTUNG !!\n\nNur nach Aufforderung betretten. Sonst Kick vom Server.","parent":"332","prefix":"LifeStream RTT Twitcher-in/Youtuber-in","minChannels":1,"maxClients":9,"codec":"4","codecQuality":"5","joinPower":25,"talkPower":0,"password":"","topic":""},"children":[{}]}]
2021-06-17T20:32:45+02:00 [simple_channel_creator:153:28] 2341
2021-06-17T20:32:45+02:00 [simple_channel_creator:152:28] === Size of JSON.stringify(parentChannels):
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> LifeStream RTT Twitcher-in/Youtuber-in 1 ### 338
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:LifeStream RTT Twitcher-in/Youtuber-in
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> Support 1 ### 318
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]Supportbereich
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> RTT Laberecke 2 ### 676
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> RTT Laberecke 1 ### 311
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 2:RTT Fahrer Laberecke
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> Unterwegs in ETS2 1 ### 324
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]⮞⮞⮞ ETS ⮜⮜⮜
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> LifeStream (Achtung! mit Ton) 1 ### 337
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:LifeStream Fahrer
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> Bauernhof 2 ### 675
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> Bauernhof 1 ### 110
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 2:╔--LS19/17/15
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> RTT Gästelounge 1 ### 306
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:RTT Gästebereich
2021-06-17T20:32:45+02:00 [simple_channel_creator:350:16] ----> Unterwegs in America 1 ### 326
2021-06-17T20:32:45+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]⮞⮞⮞ ATS ⮜⮜⮜
2021-06-17T20:32:45+02:00 [simple_channel_creator:395:28] ##### SEPARATOR #####
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> LifeStream RTT Twitcher-in/Youtuber-in 1 ### 338
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> LifeStream RTT Twitcher-in/Youtuber-in 2 ### 673
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 2:LifeStream RTT Twitcher-in/Youtuber-in
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> Support 1 ### 318
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]Supportbereich
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> RTT Laberecke 1 ### 311
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:RTT Fahrer Laberecke
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> Unterwegs in ETS2 1 ### 324
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]⮞⮞⮞ ETS ⮜⮜⮜
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> LifeStream (Achtung! mit Ton) 1 ### 337
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:LifeStream Fahrer
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> Bauernhof 1 ### 110
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:╔--LS19/17/15
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> RTT Gästelounge 1 ### 306
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:RTT Gästebereich
2021-06-17T20:32:44+02:00 [simple_channel_creator:350:16] ----> Unterwegs in America 1 ### 326
2021-06-17T20:32:44+02:00 [simple_channel_creator:348:14] --> 1:[cspacer]⮞⮞⮞ ATS ⮜⮜⮜
2021-06-17T20:32:44+02:00 [simple_channel_creator:111:16] ==> First client is visible. Number of visible clients: 11
2021-06-17T20:32:44+02:00 TS |INFO | | |Statistics report: Not yet, next report on Thu Jul 8 19:48:01 2021
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2021-06-17T20:32:44+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2021-06-17T20:32:44+02:00 New connection status 4; Error 0
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2021-06-17T20:32:44+02:00 New connection status 3; Error 0
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2021-06-17T20:32:44+02:00 New connection status 2; Error 0
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2021-06-17T20:32:44+02:00 TS |DEVELOP |PktHandler |1 |Puzzle solve time: 4
2021-06-17T20:32:44+02:00 New connection status 1; Error 0
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Initiating connection: 80.241.217.192:9987
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI |1 |Connect to server: 80.241.217.192
2021-06-17T20:32:44+02:00 TS |INFO |ClientUI | |ts3server: 80.241.217.192?port=9987&nickname=Support&password=&cid=578&channelpassword=
2021-06-17T20:32:43+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/64cc5440-2a10-4f7a-83d6-85acd57badc9/ab50596c-bd1b-13ae-f32a-c3524bfff1c7/settings.db
2021-06-17T20:32:43+02:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2021-06-17T20:32:43+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2021-06-17T20:32:43+02:00 TS |INFO | | |*** Time [INIT]: 929
2021-06-17T20:32:43+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 928
2021-06-17T20:32:43+02:00 TS |INFO | | |*** Time [CHAT_WIDGETS]: 131
2021-06-17T20:32:43+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2021-06-17T20:32:43+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2021-06-17T20:32:43+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2021-06-17T20:32:43+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
pastebin
