Sinus Bot [LINUX] HELP !
MajstorrKrme
Hi, im installed SinusBot at my VPS with this link -> https://sinusbot-installer.de/
And i cant connect bot to my ts3 server they only say me this
Invalid server address, wrong password, security level too high for our identity, server doesn't accept the client version or given default channel non-existant / passworded.
Server address is correct, server dont have passsword, all information is correct !
This is instance logs (ALL LOGS)
018-10-12T18:18:51+02:00 TSClient quit.
2018-10-12T18:18:50+02:00 New connection status 0; Error 0
2018-10-12T18:18:50+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-10-12T18:18:50+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Oct 16 17:52:40 2018
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-10-12T18:18:50+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-10-12T18:18:50+02:00 New connection status 1; Error 0
2018-10-12T18:18:50+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-10-12T18:18:50+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI |1 |Initiating connection: 164.132.204.183:9987
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI |1 |Connect to server: 164.132.204.183
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI | |ts3server: 164.132.204.183?port=9987&nickname=SparrowKid&password=&channel=&channelpassword=
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/fc1a89e3-0cb6-42c8-8653-58d242253c62/b1060458-39eb-4ff5-84ec-0567db5a9904/settings.db
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-10-12T18:18:50+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-10-12T18:18:50+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2018-10-12T18:18:50+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-10-12T18:18:50+02:00 TS |INFO | | |*** Time [INIT]: 113
2018-10-12T18:18:50+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 113
2018-10-12T18:18:50+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2018-10-12T18:18:49+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-10-12T18:18:49+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-10-12T18:18:49+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-10-12T18:18:49+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-10-12T18:18:49+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2018-10-12T18:18:49+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-10-12T18:18:49+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-10-12T18:18:49+02:00 TS |INFO | | |Using hardware aes
2018-10-12T18:18:49+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018-10-12T18:18:49+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.1 (2018-08-14 14:00:36)
2018-10-12T18:18:49+02:00 Starting instance ts3server://164.132.204.183?port=9987&nickname=SparrowKid&password=&channel=&channelpassword=
2018-10-12T18:18:49+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-10-12T18:18:49+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-10-12T18:18:49+02:00 Could not create Chat-Tabletable Chat already exists
2018-10-12T18:16:20+02:00 TSClient quit.
2018-10-12T18:16:19+02:00 New connection status 0; Error 0
2018-10-12T18:16:19+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-10-12T18:16:19+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Oct 16 17:52:40 2018
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-10-12T18:16:19+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-10-12T18:16:19+02:00 New connection status 1; Error 0
2018-10-12T18:16:19+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-10-12T18:16:19+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI |1 |Initiating connection: 164.132.204.183:9987
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI |1 |Connect to server: 164.132.204.183
2018-10-12T18:16:19+02:00 TS |INFO |ClientUI | |ts3server: 164.132.204.183?port=9987&nickname=SparrowKid&password=&channel=&channelpassword=
2018-10-12T18:16:18+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/fc1a89e3-0cb6-42c8-8653-58d242253c62/b1060458-39eb-4ff5-84ec-0567db5a9904/settings.db
2018-10-12T18:16:18+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-10-12T18:16:18+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-10-12T18:16:18+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-10-12T18:16:18+02:00 TS |INFO | | |*** Time [INIT]: 153
2018-10-12T18:16:18+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 153
2018-10-12T18:16:18+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2018-10-12T18:16:18+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2018-10-12T18:16:18+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-10-12T18:16:18+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-10-12T18:16:18+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-10-12T18:16:18+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-10-12T18:16:18+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2018-10-12T18:16:18+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-10-12T18:16:18+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-10-12T18:16:18+02:00 TS |INFO | | |Using hardware aes
2018-10-12T18:16:18+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018-10-12T18:16:18+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.1 (2018-08-14 14:00:36)
2018-10-12T18:16:18+02:00 Starting instance ts3server://164.132.204.183?port=9987&nickname=SparrowKid&password=&channel=&channelpassword=
2018-10-12T18:16:18+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-10-12T18:16:18+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-10-12T18:16:18+02:00 Could not create Chat-Tabletable Chat already exists
2018-10-12T18:13:20+02:00 TSClient quit.
2018-10-12T18:13:19+02:00 New connection status 0; Error 0
2018-10-12T18:13:19+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-10-12T18:13:19+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018-10-12T18:13:19+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-10-12T18:13:18+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Oct 16 17:52:40 2018
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-10-12T18:13:18+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-10-12T18:13:18+02:00 New connection status 1; Error 0
2018-10-12T18:13:18+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 9
2018-10-12T18:13:18+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 6
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-10-12T18:13:18+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI |1 |Initiating connection: 164.132.204.183:9987
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI |1 |Connect to server: 164.132.204.183
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI | |ts3server: 164.132.204.183?port=9987&nickname=SparrowKid&password=&channel=&channelpassword=
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/fc1a89e3-0cb6-42c8-8653-58d242253c62/b1060458-39eb-4ff5-84ec-0567db5a9904/settings.db
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-10-12T18:13:18+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-10-12T18:13:18+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-10-12T18:13:18+02:00 TS |INFO | | |*** Time [INIT]: 118
2018-10-12T18:13:18+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 117
2018-10-12T18:13:18+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2018-10-12T18:13:18+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2018-10-12T18:13:18+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-10-12T18:13:18+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
Check if the UID or IP of your Client is not banned
also check if the security level of the bots identity is high enough
