dexatrin82
Sinusbot Version: 0.11.0
I start sinusbot, seems to load up fine, my instances log in get their channels and everything looks fine, until I go into their channel and see that they are open-mic and echoing everything said in the room.
I do not have visual access to the X server, so I cannot open the client and disable the sound input device. I am trying to figure this out all I have shell commands to work with.
- CPU Model: Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz
- CPU Details: 4 Core (2400 MHz)
- Distro Name: CentOS Linux release 7.4.1708 (Core)
- Kernel Version: 3.10.0-693.2.2.el7.centos.plus.x86_64
- Platform: x86_64 [xenxen-hvm]
- 2GB RAM
2018/01/23 17:31:56 X [MAIN] Starting up fake x-server...
Version: 0.11.0-8e5f1a2
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin Jail.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin MusicSoundText_Message_On_Join.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin Server_Join_Alert.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/01/23 17:31:56 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/01/23 17:31:56 6c77be66 INFO Loading instances
2018/01/23 17:31:56 6c77be66 INFO Loading instance://4617406b-edc4-4b0c-8bec-86fe1d29c7f4
2018/01/23 17:31:56 6c77be66 4617406b INFO Initialization complete
2018/01/23 17:31:56 6c77be66 4617406b INFO Auto-Starting 6c77be66-922b-40c4-a6f2-32412c532538/4617406b-edc4-4b0c-8bec-86fe1d29c7f4 in 500 ms...
2018/01/23 17:31:56 6c77be66 INFO Loading instance://04fbd771-201e-42c6-9494-8df35d1016ee
2018/01/23 17:31:56 6c77be66 04fbd771 INFO Loading script Jail
2018/01/23 17:31:56 6c77be66 04fbd771 INFO Initialization complete
2018/01/23 17:31:56 6c77be66 04fbd771 INFO Auto-Starting 6c77be66-922b-40c4-a6f2-32412c532538/04fbd771-201e-42c6-9494-8df35d1016ee in 1000 ms...
2018/01/23 17:31:56 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2018/01/23 17:31:56 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2018/01/23 17:31:56 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2018/01/23 17:31:56 [GENERAL/RADIO ] INFO RadioStation data loaded
2018/01/23 17:31:57 [GENERAL/RADIO ] INFO Imported radio stations
2018/01/23 17:31:57 6c77be66 4617406b DEBUG Prespawn.
2018/01/23 17:31:57 6c77be66 4617406b DEBUG About to run.
2018/01/23 17:31:57 6c77be66 4617406b WARN Could not create Chat-Tabletable Chat already exists
2018/01/23 17:31:57 6c77be66 4617406b WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/01/23 17:31:57 6c77be66 4617406b WARN Could not create Notifications-Tabletable Notifications already exists
2018/01/23 17:31:57 6c77be66 4617406b DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/01/23 17:31:57 6c77be66 4617406b DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/01/23 17:31:57 6c77be66 4617406b INFO Starting instance ts3server://teamspeak.armoredpatriots.com?port=9987&nickname=The%20Greeter&password=&cid=63&channelpassword=
2018/01/23 17:31:57 X [MAIN] New connection
2018/01/23 17:31:57 6c77be66 4617406b DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/4617406b-edc4-4b0c-8bec-86fe1d29c7f4/crashdumps
2018/01/23 17:31:57 6c77be66 4617406b DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/4617406b-edc4-4b0c-8bec-86fe1d29c7f4/crashdumps
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |SystemInformation: Linux 3.10.0-693.2.2.el7.centos.plus.x86_64 #1 SMP Tue Sep 12 23:18:54 UTC 2017 x86_64 Binary: 64bit
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |DEBUG |PulseAudio | |connected to pulse audio server
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Api version is not compatible for plugin: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2018/01/23 17:31:57 6c77be66 4617406b DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |*** Time [MAINWINDOW]: 130
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |*** Time [INIT]: 130
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI | |Qt version: 5.5.0
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/4617406b-edc4-4b0c-8bec-86fe1d29c7f4/settings.db
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG Prespawn.
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG About to run.
2018/01/23 17:31:57 6c77be66 04fbd771 WARN Could not create Chat-Tabletable Chat already exists
2018/01/23 17:31:57 6c77be66 04fbd771 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/01/23 17:31:57 6c77be66 04fbd771 WARN Could not create Notifications-Tabletable Notifications already exists
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/01/23 17:31:57 6c77be66 04fbd771 INFO Starting instance ts3server://teamspeak.armoredpatriots.com?port=9987&nickname=Dexatrin%27s%20Assistant&password=&cid=94&channelpassword=
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI | |ts3server: teamspeak.armoredpatriots.com?port=9987&nickname=The%20Greeter&password=&cid=63&channelpassword=
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Connect to server: teamspeak.armoredpatriots.com
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Trying to resolve teamspeak.armoredpatriots.com
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |TSDNS | |No TSDNS found at "armoredpatriots.com"
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |TSDNS | |DNS resolve successful, "teamspeak.armoredpatriots.com"=209.95.52.67
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.teamspeak.armoredpatriots.com"
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/04fbd771-201e-42c6-9494-8df35d1016ee/crashdumps
2018/01/23 17:31:57 6c77be66 04fbd771 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/04fbd771-201e-42c6-9494-8df35d1016ee/crashdumps
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Lookup finished: 209.95.52.67 9987 teamspeak.armoredpatriots.com 0 0
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Resolve successful: 209.95.52.67:9987
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Initiating connection: 209.95.52.67:9987 teamspeak.armoredpatriots.com
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |SystemInformation: Linux 3.10.0-693.2.2.el7.centos.plus.x86_64 #1 SMP Tue Sep 12 23:18:54 UTC 2017 x86_64 Binary: 64bit
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.pa.dummy.playbackdefault
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.pa.dummy.capturedefault
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |DEBUG |PulseAudio | |connected to pulse audio server
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Connect status: Connected
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/01/23 17:31:57 6c77be66 04fbd771 INFO TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI |1 |Connect status: Connection established
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |PermManager | |Loading permissions from cache
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Statistics report: Not yet, next report on Fri Feb 9 16:48:57 2018
2018/01/23 17:31:57 6c77be66 4617406b INFO TS |INFO | | |Failed to download remote image: Error downloading http://www.armoredpatriots.com/images/103.png - server replied: Not Found 203
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO | | |Api version is not compatible for plugin: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2018/01/23 17:31:58 X [MAIN] New connection
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO | | |*** Time [MAINWINDOW]: 140
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO | | |*** Time [INIT]: 140
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI | |Qt version: 5.5.0
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/6c77be66-922b-40c4-a6f2-32412c532538/04fbd771-201e-42c6-9494-8df35d1016ee/settings.db
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI | |ts3server: teamspeak.armoredpatriots.com?port=9987&nickname=Dexatrin%27s%20Assistant&password=&cid=94&channelpassword=
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Connect to server: teamspeak.armoredpatriots.com
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Trying to resolve teamspeak.armoredpatriots.com
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |TSDNS | |DNS resolve successful, "teamspeak.armoredpatriots.com"=209.95.52.67
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.teamspeak.armoredpatriots.com"
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Lookup finished: 209.95.52.67 9987 teamspeak.armoredpatriots.com 0 0
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Resolve successful: 209.95.52.67:9987
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Initiating connection: 209.95.52.67:9987 teamspeak.armoredpatriots.com
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.pa.dummy.playbackdefault
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.pa.dummy.capturedefault
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Connect status: Connected
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI |1 |Connect status: Connection established
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |PermManager | |Loading permissions from cache
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO | | |Failed to download remote image: Error downloading http://www.armoredpatriots.com/images/103.png - server replied: Not Found 203
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018/01/23 17:31:58 6c77be66 04fbd771 INFO TS |INFO | | |Statistics report: Not yet, next report on Fri Feb 16 17:11:48 2018
2018/01/23 17:32:26 6c77be66 4617406b DEBUG Storing configuration.
2018/01/23 17:32:26 6c77be66 04fbd771 DEBUG Storing configuration.
