mmaniaque
I recently installed Sinusbot to be able to put music on a Discord server and unfortunately the bot does not emit any sound, despite several reinstallations of Sinusbot in several different versions.,
My version of SinusBot is 1.0.0-beta.10-202ee4d.
All the information about the machine, the configuration and the logs of the instance are below in this message.
Thanks for your help.
cordially
cordially
2020-02-08T13:14:53-05:00 starting voice connection
2020-02-08T13:14:53-05:00 identifying to discord
2020-02-08T13:14:53-05:00 hello: {"op":10,"d":{"heartbeat_interval":41250,"_trace":["[\"gateway-prd-main-55nr\",{\"micros\":0.0}]"]},"s":0,"t":""}
2020-02-08T13:14:53-05:00 Discord bot account valid (id: 670413076566376449, name: PRIVATE-NAME)
2020-02-08T13:14:52-05:00 imported module: command
2020-02-08T13:14:52-05:00 resolving module command
2020-02-08T13:14:52-05:00 script sinusbot-commands loaded
2020-02-08T13:14:52-05:00 registered callback for event trackEnd
2020-02-08T13:14:52-05:00 registered callback for event trackInfo
2020-02-08T13:14:52-05:00 registered callback for event discord:MESSAGE_REACTION_ADD
2020-02-08T13:14:52-05:00 registered callback for event load
2020-02-08T13:14:52-05:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-02-08T13:14:52-05:00 script command loaded
2020-02-08T13:14:52-05:00 module registered as command
TS3Path = ""
ExternalFileBase = ""
LicenseKey = "N6gy7uyar85x3bvISdVenb4DRL28r4OCgiEGHVYNJDk="
DevMode = false
[TTS]
Enabled = false
- Kernel: Linux 4.19.0-6-amd64 x86_64
- Load Average: 0.19 0.24 0.22
- Uptime: 6 days, 22 hours, 8 minutes, 36 seconds
- OS APT Last Update: 08.02.2020 17:28:47 UTC +00:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 12
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 1
Model name: Intel(R) Xeon(R) E-2236 CPU @ 3.40GHz
CPU MHz: 953.496
Virtualization: VT-x
- RAM: 7.94 GB/31.19 GB in use (25%)
- SWAP: 0 B/1021.99 MB in use (0%)
- DISK: 7.96 GB/468.34 GB in use (1%)
- libglib: 2.58.3-2+deb10u2
- Status: running (PIDs: 30510 30509, User: sinusbot)
- TS3 Plugin: unknown (TS3client not found)
- Bot Plugin: unknown
- TS3 Client: unknown
- TS3Path = (TS3client-binary does not exist!)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2020.01.24)
- TS3Client/libqxcb-glx-integration.so:
linux-vdso.so.1 (0x00007ffd00117000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f40d721b000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f40d6ec3000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f40d6ac2000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f40d615d000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f40d5ee9000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f40d5ed9000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f40d5d54000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f40d5d33000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f40d5baf000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f40d5b95000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f40d59d4000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f40d57b6000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f40d57aa000)
/lib64/ld-linux-x86-64.so.2 (0x00007f40d7437000)
- Time (local): 08.02.2020 18:16:27 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: unknown
- youtube-dl Version: 2020.01.24
