martindines
I've discovered an interesting bug(?) that I have not been able to consistently reproduce. Apologies in advance if this is not the correct forum.
SinusBot version: 0.10.8-71ba94b
Teamspeak3 Client version: 3.0.18.2
SinusBot connects to a server with it's Microphone and Speakers disabled. I've been able to reproduce only during the first start, following initialisation with
Comparing the log file produced by successful (microphone, speakers: enabled), and unsuccessful (microphone, speakers: disabled) attempts, the difference appears to be the Speex library failing to load.
Log file from successful initialisation: successful.log.txt
Log file from unsuccessful initialisation: unsuccessful.log.txt
The notable difference appears to be the following line, which is missing from the unsuccessful startup log file:
A simple restart of SinusBot does resolve the issue; but when part of an automated provisioning script, restarting until a Speex version is present isn't ideal.
Has anyone come across this issue? Does anything look amiss in either log file? Perhaps the issue is not with SinusBot and instead with the Teamspeak 3 Client?
Thanks in advance, all!
Martin
--initonly
.Comparing the log file produced by successful (microphone, speakers: enabled), and unsuccessful (microphone, speakers: disabled) attempts, the difference appears to be the Speex library failing to load.
INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
Martin
