Sinusbot do not connect to any teamspeak servers
RazvanGFX
I've searched thru forums but I could not find any solutions so now I am here asking for help.
Here is the code from diagnostic script
 - Operating System: Ubuntu 22.04.4 LTS
 - Kernel: Linux 5.15.0-97-generic x86_64
 - Load Average: 0.13 0.07 0.04
 - Uptime: 0 days, 0 hours, 27 minutes, 26 seconds
 - OS APT Last Update: 25.02.2024 08:48:13 UTC +00:00:00
 - Shell Locale: en_US.UTF-8
    Architecture:                       x86_64
    CPU(s):                             4
    Model name:                         Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
    Thread(s) per core:                 1
    Core(s) per socket:                 1
    Socket(s):                          4
    Hypervisor vendor:                  VMware
    Virtualization type:                full
 - RAM: 597.32 MB/5.78 GB in use (10%)
 - DISK: 7.65 GB/29.42 GB in use (26%)
   - libglib: 2.72.4-0ubuntu2.2
 - Binary Info: MD5 Hash: 72d16bcac5d8e0df94ba49def894e52f, Perms: 755, User: sinusbot
 - Version:
   - LogLevel = 0
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.5.6)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2023.12.30)
    linux-vdso.so.1 (0x00007fff8f96b000)
    libswresample.so.4 => /opt/sinusbot/libswresample.so.4 (0x00007fb77d8fd000)
    libavfilter.so.8 => /opt/sinusbot/libavfilter.so.8 (0x00007fb77d4fb000)
    libavformat.so.59 => /opt/sinusbot/libavformat.so.59 (0x00007fb77d277000)
    libavcodec.so.59 => /opt/sinusbot/libavcodec.so.59 (0x00007fb77bf97000)
    libavutil.so.57 => /opt/sinusbot/libavutil.so.57 (0x00007fb77bdbc000)
    libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fb77bd9c000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb77bd97000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb77bd92000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fb77bb66000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb77ba7f000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fb77ba5f000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb77b836000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fb77d921000)
    libswscale.so.6 => /opt/sinusbot/libswscale.so.6 (0x00007fb77b789000)
 - DNS resolution check: SUCCESS [www.sinusbot.com resolved to 104.21.13.58]
    update01.sinusbot.com -> 104.21.13.58: SUCCESS [CODE #404]
 - Time (local): 25.02.2024 09:42:20 UTC +00:00:00
 - Time (remote): 25.02.2024 09:42:20 UTC +00:00:00
 - Timezone: Etc/UTC
 - TeamSpeak3 Version: 3.5.6
 - youtube-dl Version: 2023.12.30
and here from sinusbot web interface
2024-02-25T11:45:49+02:00 TSClient quit.
2024-02-25T11:45:48+02:00 New connection status 0; Error 1797
2024-02-25T11:45:48+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2024-02-25T11:45:48+02:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2024-02-25T11:45:48+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2024-02-25T11:45:43+02:00 TS |INFO | | |Statistics report: Not yet, next report on Sun Mar 3 09:35:40 2024
2024-02-25T11:45:43+02:00 TS |INFO |ClientUI | |Last update check was: Mon Jan 1 00:00:01 2035
2024-02-25T11:45:43+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2024-02-25T11:45:43+02:00 New connection status 1; Error 0
2024-02-25T11:45:43+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI |1 |Initiating connection: 89.40.104.X:9987
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI |1 |Connect to server: 89.40.104.X
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI | |ts3server: 89.40.104.X?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2024-02-25T11:45:42+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/f5760e74-cc0d-49ef-98b2-fa00e1441b9e/0adacf00-302f-4481-a558-c7cbd28b8400/settings.db
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2024-02-25T11:45:42+02:00 TS |INFO | | |*** Time [INIT]: 232
2024-02-25T11:45:42+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 232
2024-02-25T11:45:42+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2024-02-25T11:45:42+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2024-02-25T11:45:42+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2024-02-25T11:45:42+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2024-02-25T11:45:42+02:00 TS |INFO |Addons | |Checking for addon updates...
2024-02-25T11:45:42+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2024-02-25T11:45:42+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2024-02-25T11:45:42+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
2024-02-25T11:45:41+02:00 TS |INFO | | |Using hardware aes
2024-02-25T11:45:41+02:00 TS |INFO | | |SystemInformation: Linux 5.15.0-97-generic #107-Ubuntu SMP Wed Feb 7 13:26:48 UTC 2024 x86_64 Binary: 64bit
2024-02-25T11:45:41+02:00 TS |INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2024-02-25T11:45:41+02:00 Starting instance ts3server://89.40.104.X?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2024-02-25T11:45:41+02:00 Could not create Notifications-Tabletable Notifications already exists
2024-02-25T11:45:41+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2024-02-25T11:45:41+02:00 Could not create Chat-Tabletable Chat already exists
2024-02-25T11:45:39+02:00 BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC MODE OK
