sinusbot does not enter teamspeak
Lala Sabathil
.... oh boi..
and next time:
The normal way to get help in a forum:
The first thing to do is to see if you can fix the problem yourself, because you might have made a mistake.
If this is not the case, take a look at the FAQ of a forum (in our case it is here: https://forum.sinusbot.com/kb).
Then check if there are similar posts to your problem (see https://forum.sinusbot.com/search/).
If this is not the case, you will open a new post in which you stick to the guides for the post creation (in our case: https://forum.sinusbot.com/threads/read-me-before-you-post.342/).
