Solved SinusBot doesn't start after beeing stoped
Luca1337
today I wanted to let the bot rejoin on my teamspeak server so I decided to switch the bot off and on via the interface button.
The Bot succesfully disconnected from the server but now it doesn't want to join back. After I hit the button to start the bot, it immediately turns from the color green to orange. I've got some logs and system information for you.
Instance Log:
https://pastebin.com/iHDD0145
Bot Log: (Doesn't show anything special it also doesn't update)
https://pastebin.com/zYFqtEE9
- Operating System: Debian GNU/Linux 8.10 (jessie) (OpenVZ)
- Kernel: Linux 2.6.32-042stab127.2 x86_64
- Load Average: 0.45 0.29 0.10
- Uptime: 0 days, 0 hours, 46 minutes, 15 seconds
- OS APT Last Update: 09.01.2018 13:34:36 EST -05:00:00
- RAM: B/1.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 886.24 MB/24.13 GB in use (3%)
+ libglib: 2.42.1-1+b1
- Status: running (PIDs: 486 473, User: sinusbot)
- Binary: /opt/ts3soundboard/sinusbot
- Binary Info: MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339, Perms: 755, User: sinusbot
- Version: 0.10.8-71ba94b
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.01.07)
- Installed scripts: Digital_Clock.js; ZTSupport_-_SupportChannel_With_ServerGroup_Support.js; advertising.js; alonemode.js; bookmark.js; followme.js; norecording.js; rememberChannel.js; welcome.js
- Time (local): 23.01.2018 09:59:43 EST -05:00:00
- Timezone: America/New_York
- youtube-dl Version: 2018.01.07
- DiagScript Version: 0.7.0
Everything was running okay till i stoped/disconnected the bot :/
Also let me know if you need some additional informations.
I would really appreciate some help :)
DerSandmann
ich würde jetzt einfach das Verzeichnis von Teamspeak im sinusbotordner löschen und neu installieren mit der neusten Version
Luca1337
My informations after the updates
- Load Average: 0.03 0.05 0.00
- Uptime: 0 days, 1 hours, 35 minutes, 11 seconds
- DISK: 1.03 GB/23.96 GB in use (4%)
- Binary Info: MD5 Hash: f59b51a628eee417d53f6560e6365a09, Perms: 755, User: root
- Version: 0.11.0-8e5f1a2
- Bot Plugin: ce7bcdef6f438182b7c0d7dee8742510
- TS3 Client: ce7bcdef6f438182b7c0d7dee8742510
- TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.8)
- Time (local): 23.01.2018 10:48:04 EST -05:00:00
- TeamSpeak 3 Version: 3.1.8
Versuche mal das auszuführen um weitere Informationen zu bekommen:
xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Vermutlich fehlen dir einfach nur Abhängigkeiten:
apt-get install x11vnc xvfb libxcursor1 ca-certificates bzip2 libnss3 libegl1-mesa x11-xkb-utils libasound2 -y
Und es wäre sinnvoller, wenn wir das im Chat klären, da das ein Forum ist und kein Chat ;)
