2018-03-12T16:35:04+01:00 Storing configuration.
2018-03-12T16:35:04+01:00 TSClient quit.
2018-03-12T16:35:04+01:00 Closed.
2018-03-12T16:35:04+01:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2018-03-12T16:35:04+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018-03-12T16:35:04+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-03-12T16:35:03+01:00 New connection status 0; Error 1797
2018-03-12T16:35:03+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-03-12T16:35:03+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2018-03-12T16:35:03+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-03-12T16:35:00+01:00 TS |INFO |TSDNS | |No TSDNS found
2018-03-12T16:35:00+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 145.239.119.0:41144
2018-03-12T16:34:58+01:00 TS |INFO | | |Statistics report: Not yet, next report on Mon Apr 2 11:41:33 2018
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-03-12T16:34:58+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-03-12T16:34:58+01:00 New connection status 1; Error 0
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-03-12T16:34:58+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Initiating connection: 178.217.190.176:9987
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Resolve successful: 178.217.190.176:9987
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Lookup finished: ip=178.217.190.176 port=9987 query=ts-best.pl error=0
2018-03-12T16:34:58+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts3.ts-best.pl" =(h: 178.217.190.176 p:0)
2018-03-12T16:34:58+01:00 TS |INFO |TSDNS | |SRV DNS resolve successful, "_ts3._udp.ts-best.pl" =(h: ts3.ts-best.pl p:9987)
2018-03-12T16:34:58+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.ts-best.pl" Domain name not found
2018-03-12T16:34:58+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "ts-best.pl" =(h: 145.239.119.0 p:0)
2018-03-12T16:34:58+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts-best.pl" =(h: 145.239.119.0 p:0)
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Trying to resolve TS-BEst.pl
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI |1 |Connect to server: TS-BEst.pl
2018-03-12T16:34:58+01:00 TS |INFO |ClientUI | |ts3server: TS-BEst.pl?port=9987&nickname=TS-BEST%20%40%20DIAMOND%20%231%20%282%29&password=&channel=&channelpassword=
2018-03-12T16:34:57+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/ts3soundboard8001/data/ts3/80723d47-ac0f-4e71-832d-9ce4b3b1cba9/2793bc1e-481b-46f4-bd06-5a220b7317f3/settings.db
2018-03-12T16:34:57+01:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-03-12T16:34:57+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-03-12T16:34:57+01:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/ts3soundboard8001/TeamSpeak3-Client-linux_amd64/sound/nosounds
2018-03-12T16:34:57+01:00 TS |INFO | | |*** Time [INIT]: 152
2018-03-12T16:34:57+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 152
2018-03-12T16:34:57+01:00 TS |INFO | | |successfully downloaded revocation list
2018-03-12T16:34:57+01:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2018-03-12T16:34:57+01:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-03-12T16:34:57+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-03-12T16:34:57+01:00 TS |INFO |Addons | |Checking for addon updates...
2018-03-12T16:34:57+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-03-12T16:34:57+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-03-12T16:34:57+01:00 TS |INFO | | |SystemInformation: Linux 4.4.0-92-generic #115-Ubuntu SMP Thu Aug 10 09:04:33 UTC 2017 x86_64 Binary: 64bit
2018-03-12T16:34:57+01:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2018-03-12T16:34:57+01:00 TS>DUMP defined! Dumpdir is: /opt/ts3soundboard8001/data/ts3/80723d47-ac0f-4e71-832d-9ce4b3b1cba9/2793bc1e-481b-46f4-bd06-5a220b7317f3/crashdumps
2018-03-12T16:34:57+01:00 TS>Crashdump ENABLED, directory is: /opt/ts3soundboard8001/data/ts3/80723d47-ac0f-4e71-832d-9ce4b3b1cba9/2793bc1e-481b-46f4-bd06-5a220b7317f3/crashdumps
2018-03-12T16:34:57+01:00 Starting instance ts3server://TS-BEst.pl?port=9987&nickname=TS-BEST%20%40%20DIAMOND%20%231%20%282%29&password=&channel=&channelpassword=
2018-03-12T16:34:57+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-03-12T16:34:57+01:00 Could not delete from FileTransferno such table: FileTransfer
2018-03-12T16:34:57+01:00 Could not create Notifications-Tabletable Notifications already exists
2018-03-12T16:34:57+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-03-12T16:34:57+01:00 Could not create Chat-Tabletable Chat already exists
2018-03-12T16:34:57+01:00 About to run.
2018-03-12T16:34:57+01:00 Prespawn.
2018-03-12T16:34:54+01:00 TSClient quit.
2018-03-12T16:34:54+01:00 Closed.
2018-03-12T16:34:54+01:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2018-03-12T16:34:54+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018-03-12T16:34:54+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-03-12T16:34:53+01:00 New connection status 0; Error 1797
2018-03-12T16:34:53+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-03-12T16:34:53+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2018-03-12T16:34:53+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-03-12T16:34:50+01:00 TS |INFO |TSDNS | |No TSDNS found
2018-03-12T16:34:50+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 145.239.119.0:41144
2018-03-12T16:34:50+01:00 Already online.
2018-03-12T16:34:50+01:00 Prespawn.
there is a log. Bots dropped from ts and didnt reconnect. i check log level, bans, floodbans, domain, nick size.
