today I installed the newest Sinusbot Version on my Linux Server(Debian 9). I wanted to connect to a Teamspeak with the same IP but he didn't connect. On other Servers it worked fine. Specs:
Newest Sinusbot Version, Teamspeak Client 3.0.18.2/Teamspeak Server 3.1.0
Operation System: Debian 9
VPS: 50GB Ram, 10 Core Intel Xeon E5 2620v3
Browser: Opera
I tried it with LogLevel=10 but it didn't changes anything.
Browser: Opera
LogLevel = 15
LicenseKey = "s/yy+nIN9jusjUsaDQkTg5FE9hNOGDO9v0HCQEdbG3Q="
UserAgent = "SinusBot (0.10.8-71ba94b)"
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO Starting instance ts3server://5.189.184.30?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2018/02/24 06:27:39 X [MAIN] New connection
2018/02/24 06:27:39 a773ffd5 c5fdbf49 DEBUG TS>Crashdump ENABLED, directory is: /opt/ts3soundboard/data/ts3/a773ffd5-6b92-4278-ab46-4c810fc36007/c5fdbf49-e999-487d-a733-9e8b2fd3494b/crashdumps
2018/02/24 06:27:39 a773ffd5 c5fdbf49 DEBUG TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/a773ffd5-6b92-4278-ab46-4c810fc36007/c5fdbf49-e999-487d-a733-9e8b2fd3494b/crashdumps
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |SystemInformation: Linux 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u2 (2018-02-21) x86_64 Binary: 64bit
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Using hardware aes
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |ERROR |PulseAudio | |pa_context_connect failed
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2018/02/24 06:27:39 a773ffd5 c5fdbf49 DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |*** Time [MAINWINDOW]: 125
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |*** Time [INIT]: 126
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI | |Qt version: 5.5.0
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI | |Using configuration location: /opt/ts3soundboard/data/ts3/a773ffd5-6b92-4278-ab46-4c810fc36007/c5fdbf49-e999-487d-a733-9e8b2fd3494b/settings.db
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI | |ts3server: 5.189.184.30?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI |1 |Connect to server: 5.189.184.30
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI |1 |Initiating connection: 5.189.184.30:9987 5.189.184.30
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO New connection status 1; Error 0
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018/02/24 06:27:39 a773ffd5 c5fdbf49 INFO TS |INFO | | |Statistics report: Not yet, next report on Thu Mar 15 06:02:25 2018
