Sinusbot einstellungen laden nicht
The100
Hallo also ich komme in das sinusbot webinterface und das alles aber sobald ich instance einstellungen anklicke ladet der ewig und zeigt mir nichts an das spuckt er im logfile aus was kann ich tun kann wer helfen der sich mit dem problem auskennt???
2016-03-11T18:22:34+01:00 EOF
2016-03-11T18:22:34+01:00 Socket closed.
2016-03-11T18:22:34+01:00 TSClient quit.
2016-03-11T18:22:34+01:00 TS>mainloop quit
2016-03-11T18:22:34+01:00 TS>An error has occurred: Please report this on the official forums. Guru Meditation #004-801-012
2016-03-11T18:22:34+01:00 TS |INFO | | |*** Time [SERVERVIEWMANAGER]: 184
2016-03-11T18:22:34+01:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2016-03-11T18:22:34+01:00 TS |INFO | | |*** Time [SERVERVIEW]: 127
2016-03-11T18:22:33+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2016-03-11T18:22:33+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2016-03-11T18:22:33+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2016-03-11T18:22:33+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2016-03-11T18:22:33+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2016-03-11T18:22:33+01:00 TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2016-03-11T18:22:33+01:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2016-03-11T18:22:33+01:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2016-03-11T18:22:33+01:00 TS |INFO | | |Using hardware aes
2016-03-11T18:22:33+01:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u4 (2016-02-29) x86_64 Binary: 64bit
2016-03-11T18:22:33+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2016-03-11T18:22:33+01:00 TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data//ts3/37c61596-5d9e-4258-bf84-b88304bf429c/833b63fb-e419-421c-ba7c-9ffce48cefdf/crashdumps
2016-03-11T18:22:33+01:00 TS>Crashdump ENABLED, directory is: /opt/ts3soundboard/data//ts3/37c61596-5d9e-4258-bf84-b88304bf429c/833b63fb-e419-421c-ba7c-9ffce48cefdf/crashdumps
2016-03-11T18:22:33+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
das schreibt mir putty
bot@srv1711:~$ cd /opt/ts3soundboard/cd /opt/ts3soundboard/
bash: cd: /opt/ts3soundboard/cd: Datei oder Verzeichnis nicht gefunden
bot@srv1711:/opt/ts3soundboard$ su root
Passwort:
root@srv1711:/opt/ts3soundboard# apt-get install screen
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Vorgeschlagene Pakete:
iselect screenie byobu
Die folgenden NEUEN Pakete werden installiert:
screen
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 569 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 930 kB Plattenplatz zusätzlich benutzt.
Holen: 1 http://ftp.uni-erlangen.de/debian/ jessie/main screen amd64 4.2.1-3+deb 8u1 [569 kB]
Es wurden 569 kB in 0 s geholt (11,4 MB/s).
Vormals nicht ausgewähltes Paket screen wird gewählt.
(Lese Datenbank ... 140965 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../screen_4.2.1-3+deb8u1_amd64.deb ...
Entpacken von screen (4.2.1-3+deb8u1) ...
Trigger für systemd (215-17+deb8u3) werden verarbeitet ...
Trigger für install-info (5.2.0.dfsg.1-6) werden verarbeitet ...
Trigger für man-db (2.7.0.2-5) werden verarbeitet ...
screen (4.2.1-3+deb8u1) wird eingerichtet ...
root@srv1711:/opt/ts3soundboard# su bot
bot@srv1711:/opt/ts3soundboard$ script /dev/null
Script started, file is /dev/null
bot@srv1711:/opt/ts3soundboard$ screen -S uhr xinit /opt/ts3soundboard/sinusbot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
st_plugin
2016/03/11 18:22:33 37c61596 833b63fb INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2016/03/11 18:22:34 37c61596 833b63fb INFO TS |INFO | | |*** Time [SERVERVIEW]: 127
2016/03/11 18:22:34 37c61596 833b63fb INFO TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2016/03/11 18:22:34 37c61596 833b63fb INFO TS |INFO | | |*** Time [SERVERVIEWMANAGER]: 184
2016/03/11 18:22:34 X [MAIN] New connection
2016/03/11 18:22:34 X [MAIN] Disconnected: 0
2016/03/11 18:22:34 37c61596 833b63fb INFO TS>An error has occurred: Please report this on the official forums. Guru Meditation #004-801-012
2016/03/11 18:22:34 37c61596 833b63fb INFO TS>mainloop quit
2016/03/11 18:22:34 X [MAIN] Disconnected: 3
2016/03/11 18:22:34 37c61596 833b63fb INFO TSClient quit.
2016/03/11 18:22:34 37c61596 833b63fb INFO Socket closed.
2016/03/11 18:22:34 37c61596 833b63fb WARN EOF
tracks 10140
2016/03/11 18:22:36 [GENERAL/RADIO ] INFO RadioStation data loaded
2016/03/11 18:22:37 [GENERAL/RADIO ] INFO Imported radio stations
2016/03/11 18:23:50 37c61596 INFO LOGIN [admin] OK
