Solved Sinusbot geht nach gewisser Zeit nicht mehr
2018-03-26T22:11:42+02:00 Storing configuration.
2018-03-26T22:11:31+02:00 Loading script alonemode
2018-03-26T22:11:31+02:00 db is a restricted module that needs to be enabled via special privileges in the config.ini (requested by support-pp)
2018-03-26T22:11:31+02:00 require() could not resolve import: dateformat
2018-03-26T22:11:31+02:00 Loading script support-pp
2018-03-26T22:11:31+02:00 Loading script PrivatChannelManager
2018-03-26T22:11:31+02:00 Loading script (autorun) OKlib
2018-03-26T22:11:14+02:00 New channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 62cdf402-9bf2-41b3-95c2-3d53ceb5fe51 (cc 0)
2018-03-26T22:11:14+02:00 Playing idle tracktrack://e8adaac6-c3dd-479a-9074-500ebd7d82f9
2018-03-26T22:11:14+02:00 support-pp:4014 Queue trach finnish
2018-03-26T22:11:14+02:00 Done playing
2018-03-26T22:11:14+02:00 Channels now zero
2018-03-26T22:11:14+02:00 Deleting channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 34ce9cdd-3916-4fff-b8f1-9866eb16cacf (cc 1)
2018-03-26T22:11:14+02:00 Removing closed channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 34ce9cdd-3916-4fff-b8f1-9866eb16cacf
2018-03-26T22:11:12+02:00 Storing configuration.
2018-03-26T22:11:11+02:00 PRIVATE-CHAT [SupportBOT] Error while creating your private channel!
2018-03-26T22:11:11+02:00 Could not get create channel: insufficient client permissions
2018-03-26T22:11:11+02:00 2568/insufficient client permissions/i_channel_create_modify_with_temp_delete_delay
2018-03-26T22:11:11+02:00 Awaiting Callback (1): PR:{478a1768-3dc3-44a8-978c-5a83b41a1e16}:202/CCRE
2018-03-26T22:11:11+02:00 PRIVATE-CHAT [SupportBOT] Can not locate your private channel!
2018-03-26T22:11:11+02:00 PRIVATE-CHAT [SupportBOT] [B]Support | [/B]
2018-03-26T22:11:11+02:00 _MrForum_ // Test 2 joined the channel
2018-03-26T22:11:05+02:00 PRIVATE-CHAT [SupportBOT] [B]ChannelEdit | [/B] All Support Channel are now open
2018-03-26T22:11:05+02:00 Awaiting Callback (2): PR:{478a1768-3dc3-44a8-978c-5a83b41a1e16}:196/CUPD
2018-03-26T22:11:05+02:00 PRIVATE-CHAT [Joooonathan] !open
2018-03-26T22:11:01+02:00 Loading script alonemode
2018-03-26T22:11:01+02:00 Loading script PrivatChannelManager
2018-03-26T22:11:01+02:00 db is a restricted module that needs to be enabled via special privileges in the config.ini (requested by support-pp)
2018-03-26T22:11:01+02:00 require() could not resolve import: dateformat
2018-03-26T22:11:01+02:00 Loading script support-pp
2018-03-26T22:11:01+02:00 Loading script (autorun) OKlib
2018-03-26T22:10:58+02:00 Loading script PrivatChannelManager
2018-03-26T22:10:58+02:00 support-channel manager_de:354 ChannelDescriptionSupport Enabled!
2018-03-26T22:10:58+02:00 support-channel manager_de:340 ChannelNameSupport Enabled!
2018-03-26T22:10:58+02:00 support-channel manager_de:326 CommandSupport Enabled!
2018-03-26T22:10:58+02:00 support-channel manager_de:317 TimeSupport Disabled
2018-03-26T22:10:58+02:00 Loading script support-channel manager_de
2018-03-26T22:10:58+02:00 Loading script alonemode
2018-03-26T22:10:58+02:00 Loading script (autorun) OKlib
2018-03-26T22:10:50+02:00 PRIVATE-CHAT [Joooonathan] !open
2018-03-26T22:10:42+02:00 Storing configuration.
2018-03-26T22:10:35+02:00 Loading script PrivatChannelManager
2018-03-26T22:10:35+02:00 Loading script alonemode
2018-03-26T22:10:35+02:00 Loading script (autorun) OKlib
2018-03-26T22:10:12+02:00 Storing configuration.
2018-03-26T22:10:10+02:00 Loading script alonemode
2018-03-26T22:10:10+02:00 Loading script PrivatChannelManager
2018-03-26T22:10:10+02:00 Loading script (autorun) OKlib
2018-03-26T22:09:42+02:00 Storing configuration.
2018-03-26T22:09:42+02:00 PRIVATE-CHAT [SupportBOT] Error while creating your private channel!
2018-03-26T22:09:42+02:00 Could not get create channel: insufficient client permissions
2018-03-26T22:09:42+02:00 2568/insufficient client permissions/i_channel_create_modify_with_temp_delete_delay
2018-03-26T22:09:42+02:00 Awaiting Callback (1): PR:{478a1768-3dc3-44a8-978c-5a83b41a1e16}:192/CCRE
2018-03-26T22:09:42+02:00 alonemode :30 Ending AloneMode...
2018-03-26T22:09:42+02:00 Joooonathan joined the channel
2018-03-26T22:09:41+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:09:37+02:00 New channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 34ce9cdd-3916-4fff-b8f1-9866eb16cacf (cc 0)
2018-03-26T22:09:37+02:00 Playing idle tracktrack://e8adaac6-c3dd-479a-9074-500ebd7d82f9
2018-03-26T22:09:37+02:00 Done playing
2018-03-26T22:09:37+02:00 Channels now zero
2018-03-26T22:09:37+02:00 Deleting channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID a2a26f53-f229-4104-aee7-d336773ba702 (cc 1)
2018-03-26T22:09:37+02:00 Removing closed channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID a2a26f53-f229-4104-aee7-d336773ba702
2018-03-26T22:09:37+02:00 PRIVATE-CHAT [SupportBOT] Error while creating your private channel!
2018-03-26T22:09:37+02:00 Could not get create channel: insufficient client permissions
2018-03-26T22:09:37+02:00 Awaiting Callback (1): PR:{478a1768-3dc3-44a8-978c-5a83b41a1e16}:186/CCRE
2018-03-26T22:09:37+02:00 2568/insufficient client permissions/i_channel_create_modify_with_temp_delete_delay
2018-03-26T22:09:37+02:00 Joooonathan joined the channel
2018-03-26T22:09:32+02:00 Loading script alonemode
2018-03-26T22:09:32+02:00 Loading script PrivatChannelManager
2018-03-26T22:09:32+02:00 Loading script (autorun) OKlib
2018-03-26T22:08:12+02:00 Storing configuration.
2018-03-26T22:08:01+02:00 New channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID a2a26f53-f229-4104-aee7-d336773ba702 (cc 0)
2018-03-26T22:08:01+02:00 Playing idle tracktrack://e8adaac6-c3dd-479a-9074-500ebd7d82f9
2018-03-26T22:08:00+02:00 Done playing
2018-03-26T22:08:00+02:00 Channels now zero
2018-03-26T22:08:00+02:00 Deleting channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 4436b521-7012-421c-b59c-a32991d1f325 (cc 1)
2018-03-26T22:08:00+02:00 Removing closed channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 4436b521-7012-421c-b59c-a32991d1f325
2018-03-26T22:07:12+02:00 Storing configuration.
2018-03-26T22:06:54+02:00 Loading script alonemode
2018-03-26T22:06:54+02:00 Loading script PrivatChannelManager
2018-03-26T22:06:54+02:00 Loading script (autorun) OKlib
2018-03-26T22:06:42+02:00 Storing configuration.
2018-03-26T22:06:24+02:00 New channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID 4436b521-7012-421c-b59c-a32991d1f325 (cc 0)
2018-03-26T22:06:24+02:00 Playing idle tracktrack://e8adaac6-c3dd-479a-9074-500ebd7d82f9
2018-03-26T22:06:23+02:00 Done playing
2018-03-26T22:06:23+02:00 Channels now zero
2018-03-26T22:06:23+02:00 Deleting channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID db0f38fb-9b56-4c06-aed5-4eee41d25512 (cc 1)
2018-03-26T22:06:23+02:00 Removing closed channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID db0f38fb-9b56-4c06-aed5-4eee41d25512
2018-03-26T22:06:22+02:00 PRIVATE-CHAT [SupportBOT] You can not request a private channel!
2018-03-26T22:06:22+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:06:22+02:00 Awaiting Callback (1): PR:{478a1768-3dc3-44a8-978c-5a83b41a1e16}:152/KICK
2018-03-26T22:06:22+02:00 alonemode :30 Ending AloneMode...
2018-03-26T22:06:22+02:00 Joooonathan joined the channel
2018-03-26T22:06:21+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:06:19+02:00 Loading script PrivatChannelManager
2018-03-26T22:06:19+02:00 Loading script alonemode
2018-03-26T22:06:19+02:00 Loading script (autorun) OKlib
2018-03-26T22:05:12+02:00 Storing configuration.
2018-03-26T22:04:47+02:00 New channel e8adaac6-c3dd-479a-9074-500ebd7d82f9 () ID db0f38fb-9b56-4c06-aed5-4eee41d25512 (cc 0)
2018-03-26T22:04:47+02:00 Playing idle tracktrack://e8adaac6-c3dd-479a-9074-500ebd7d82f9
Das die teamspeak clients austimen?
logs wären sinnvoll, ohne wirds schwer etwas nachzuvollziehen
Hast du eine Idee? :(
Hier noch einmal ein neuer Log:
2018-03-28T14:06:24+02:00 TS |INFO |PktHandler | |Dropping client 11 because of resend timeout
2018-03-28T14:06:24+02:00 TS |INFO |PktHandler | |Cleaning up connection because of 13 resends of COMMAND packet
2018-03-28T09:13:44+02:00 TS |INFO | | |successfully downloaded revocation list
2018-03-27T21:28:44+02:00 TS |INFO | | |successfully downloaded revocation list
2018-03-27T09:43:44+02:00 TS |INFO | | |successfully downloaded revocation list
2018-03-27T06:22:09+02:00 alonemode :42 Starting AloneMode...
2018-03-27T03:13:22+02:00 alonemode :42 Starting AloneMode...
2018-03-27T00:45:36+02:00 alonemode :42 Starting AloneMode...
2018-03-27T00:13:38+02:00 alonemode :42 Starting AloneMode...
2018-03-27T00:13:37+02:00 alonemode :42 Starting AloneMode...
2018-03-27T00:12:15+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:51:38+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:720/GCLL'
2018-03-26T22:50:38+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:50:24+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:49:47+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:49:36+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:49:34+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:49:05+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:48:53+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:21:27+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:57+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:28+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:26+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:22+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:14+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:17:12+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:532/GCLL'
2018-03-26T22:17:01+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:16:59+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:490/GCLL'
2018-03-26T22:16:46+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:451/GCLL'
2018-03-26T22:16:46+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:16:40+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:16:35+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:16:32+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:408/GCLL'
2018-03-26T22:16:17+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:15:49+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:11:20+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:11:14+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:11:11+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:10:41+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:09:42+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:09:37+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:05:57+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:321/GCLL'
2018-03-26T22:05:44+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:278/GCLL'
2018-03-26T22:05:00+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:250/GCLL'
2018-03-26T22:04:47+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:208/GCLL'
2018-03-26T22:04:30+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:164/GCLL'
2018-03-26T22:03:50+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:33+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:32+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:31+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:30+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:24+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:03:18+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:48+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:40+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:39+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:34+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:29+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:07+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:02:06+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:00:57+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:00:56+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:00:26+02:00 alonemode :42 Starting AloneMode...
2018-03-26T22:00:25+02:00 alonemode :42 Starting AloneMode...
2018-03-26T21:59:12+02:00 Storing configuration.
2018-03-26T21:58:45+02:00 alonemode :42 Starting AloneMode...
2018-03-26T21:58:45+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{7f0e27dc-67b8-4950-9c5a-bf73aeed5a7e}:77/GCLL'
2018-03-26T21:58:45+02:00 PRIVATE-CHAT [TeamForum.eu - BOT] ᅟᅟᅟᅟᅟᅟᅟᅟ ᅟᅟᅟᅟᅟᅟᅟᅟ » [B]Viel Spaß [COLOR=seagreen]I love Radio[/COLOR] auf unserem TeamSpeak-Server![/B] » Wir sind ein Minesucht.net Clan, welcher bald eröffnen wird. » Bei [COLOR=royalblue]Fragen [/COLOR] und [COLOR=royalblue]Problemen [/COLOR]kannst du dich jederzeit an unseren [URL=https://teamforum.eu/forum/board/17-support/][COLOR=royalblue]Forum-Support[/COLOR][/URL] wenden. » Joine auf den Minecraft-Server "teamforum.eu", um dich zu [B]verifizieren[/B]. » Du bist bereits [B]3[/B] mal auf unseren TeamSpeak³-Server gejoint. » Danke für deine Unterstützung. [B][COLOR=crimson]<3[/COLOR][/B]
2018-03-26T21:58:45+02:00 TS>invalid utf8 string send to logging
2018-03-26T21:58:45+02:00 New connection status 4; Error 0
2018-03-26T21:58:45+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-03-26T21:58:45+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-03-26T21:58:45+02:00 Error in script (event clientMove): TypeError: Cannot access member 'getClientCount' of undefined at alonemode.js:28:13
2018-03-26T21:58:45+02:00 New connection status 3; Error 0
2018-03-26T21:58:45+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-03-26T21:58:45+02:00 New connection status 2; Error 0
2018-03-26T21:58:45+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-03-26T21:58:45+02:00 TS |INFO | | |Statistics report: Not yet, next report on Sun Apr 8 18:24:24 2018
2018-03-26T21:58:45+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-03-26T21:58:44+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-03-26T21:58:44+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 5
2018-03-26T21:58:44+02:00 New connection status 1; Error 0
2018-03-26T21:58:44+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-03-26T21:58:44+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-03-26T21:58:44+02:00 Deleting channel 15c6ad0a-9485-4dd7-91e1-3bc394c010ff () ID f4312f74-fe35-4ece-8427-83b2c4dac1e2 (cc 2)
2018-03-26T21:58:44+02:00 Removing closed channel 15c6ad0a-9485-4dd7-91e1-3bc394c010ff () ID f4312f74-fe35-4ece-8427-83b2c4dac1e2
