Sinusbot has mirchphone and speaker disabled
JustSpEcTeR
Hello today i installed and re installed sinusbot a lot of time but when it enters on the server i dont know how and why it has speaker and microphone disabled
JustSpEcTeR
- Operating System: Ubuntu 14.04.6 LTS (OpenVZ)
- Kernel: Linux 2.6.32-openvz-042stab134.7-amd64 x86_64
- Load Average: 0.10 0.13 0.10
- Uptime: 0 days, 1 hours, 30 minutes, 36 seconds
- OS APT Last Update: 30.08.2019 15:08:33 EDT -04:00:00
- Shell Locale: (not set)
CPU(s): 8
CPU MHz: 1438.975
Virtualization: VT-x
- RAM: B/1.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 1.59 GB/30.00 GB in use (5%)
- libglib: 2.40.2-0ubuntu1.1
- Webinterface: port locally not reachable (Port: 8089)
- Binary: /opt/SinusPort-8089/sinusbot
- Binary Info: MD5 Hash: d770dee2259d159aa78550962d3251e3, Perms: 755, User: SinusPort-8089
- TS3Path = TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.8)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.08.13)
- TS3Client/libqxcb-glx-integration.so: yes
linux-vdso.so.1 => (0x00007fff18861000)
libswresample.so.2 => /opt/SinusPort-8089/libswresample.so.2 (0x00007fcc8e4ab000)
libavfilter.so.6 => /opt/SinusPort-8089/libavfilter.so.6 (0x00007fcc8e153000)
libavformat.so.57 => /opt/SinusPort-8089/libavformat.so.57 (0x00007fcc8dd52000)
libavcodec.so.57 => /opt/SinusPort-8089/libavcodec.so.57 (0x00007fcc8d3ec000)
libavutil.so.55 => /opt/SinusPort-8089/libavutil.so.55 (0x00007fcc8d178000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fcc8cf6d000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fcc8cc66000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fcc8ca48000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fcc8c744000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fcc8c52d000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcc8c164000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fcc8bf4b000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fcc8bd42000)
/lib64/ld-linux-x86-64.so.2 (0x00005639bb936000)
- Time (local): 30.08.2019 16:09:27 EDT -04:00:00
- Timezone: America/New_York
- TeamSpeak3 Version: 3.1.8 (vulnerable! outdated!)
- youtube-dl Version: 2019.08.13
GamerMarc
Aight, you are not getting any type of help if you use a Multi Script to create Unlimited Instances on SinusBot
CPU(s): 8
CPU MHz: 1438.975
