Sinusbot in CentOS
clack
Hello Guys.
I install sinusbot in CentOS release 6.8 (Final) .
But instance not start and give this ERROR :
2016-06-28T05:59:27+04:30 Starting instance ts3server://x.x.x.x?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-06-28T05:59:26+04:30 BOT-CONFIG [admin] NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2016-06-28T05:58:18+04:30 TSClient quit.
2016-06-28T05:58:18+04:30 Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
kanalumaddela
You have to set the server that the bot will connect too by changing the options in the panel. Connect by going to http://<ip>:8087 and login with username: admin, password: foobar. Then go to instance settings and change those settings.
clack
Thank You
I know how work by sinusbot.
But in centos sinusbot instance not start correctly .
Qhiliqq
Licensed Partner
Which CentOS?
Self installed or installer?
More informations please...
Qhiliqq
Licensed Partner
Ouh sorry.
Jep its CentOS 6.8 thats your problem.
Maybe @Xuxe know something about this.
Qhiliqq
Licensed Partner
CentOS 7 will work without problems.
Xuxe is already in this topic... everybody can see this thread...
Change to CentOS 7 or use a smoother OS like Debian :)
clack
CentOS 6.8 is better for my work :(
If sinusbot working in Centos 6.8 is better .
Qhiliqq
Licensed Partner
As far I can remember you have to build libs yourself in CentOS 6 ...
Please wait for his answer.
But for what do you need CentOS 6.8?
clack
I install some programs in my CentOS...
They working in CentOS 6.8 ,only.
& if i reinstall Os all data Deleted ... and programs not working .
Okay TanQ:) I'm waiting for his Replay.
I'm Waiting .
Haha. Hi,
AFAIK you have only to build glibc by your own, this is required for the Teamspeak Client, maybe a proper CentOS repository has this already take a look in the Thread "CentOS 6 install guide" for the guide how 2 build glibc your own or search a repository for CentOS.
You need a glibc Version: >= 2.19 :) But keep in mind the Bot on CentOS or other Distributions off side from Debian are very Experimental and we can may not give support for it. A good basic Linux knowledge is required for compiling the things well.
clack
Haha. Hi,
https://forum.sinusbot.com/threads/centos-6-install-guide.388/
Yum update
yum install  firefox xorg-x11-server-Xvfb x11vnc xinit xvfb libxcursor1 ca-certificates bzip2 curl libglib2.0-0 xorg-x11-server-Xorg vnc-server gnome-desktop xorg-x11-xinit xterm gnome-applets gnome-session gnome-themes gnome-panel gdm firefox dbus-x11 libstdc++-devel.i686 glibc-devel.i686
youtube-dl
Just do this work and then install sinusbot by installer script?
Which version of teamspeak for centOS? It's not important?
**) How install glibc Version: >= 2.19
In my CentOS = ldd (GNU libc) 2.12
Error :
2016/06/29 14:02:03 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/06/29 14:02:03 5c7c6b0b 82b774f0 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016/06/29 14:02:03 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016/06/29 14:02:03 5c7c6b0b 82b774f0 DEBUG  EOF
2016/06/29 14:02:03 5c7c6b0b 82b774f0 INFO   TSClient quit.
2016/06/29 14:02:04 [GENERAL/RADIO  ] INFO   Imported radio stations
It depends on which Client Version you use, using a old client is not a good option because of Security and may newer server's won't let the client connect.
The installer script also works for CentOS (6 and 7), but it don't take care about your Librarys.
Your logg says the Client requires 2.14 you use 2.12 the problem is clear? ;) - As i said you have to search by your self, CentOS is not official supported by us. The chance to break your Server is high if you don't know what you do.
May you find here the solution: https://wiki.centos.org/de/AdditionalResources/Repositories/
clack
I search and not found anything .
sinusbot work in CentOS 7 Correctly ,Buy not work in CentOS 6.8 .
Send me commands that fix this ERROR in CentOS 6.8 ,please.
slurm
CentOS is just not officially supported. But it's nice to see that even the ungrateful guys demanding cracks for the bot on other forums (like clack) are getting proper support here. :)
clack
You are very stupid and Dunderhead that type unrelated post in my thread .
Reported.
Something Off-topic but i agree ;)
Reported.
It's Off-topic but just the truth. So i don't understand why you instant rage and call him stupid.
What ever:
As we have multiple times said, search for your self or use a other distro.
