SinusBot Instance "TSClient quit"
zinio
 - Operating System: Debian GNU/Linux 9.13 (stretch)
 - Kernel: Linux 4.9.0-19-amd64 x86_64
 - Load Average: 0.20 0.18 0.12
 - Uptime: 0 days, 1 hours, 15 minutes, 34 seconds
 - OS APT Last Update: 07.08.2023 20:49:14 CEST +02:00:00
 - Shell Locale: de_DE.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            AMD EPYC 7352 24-Core Processor
    CPU MHz:               2299.998
    Virtualization:        AMD-V
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 2.05 GB/3.86 GB in use (53%)
 - DISK: 16.71 GB/19.66 GB in use (85%)
   - libglib: 2.50.3-2+deb9u3
 - Status: running (PIDs: 3763 3762, User: carlos)
 - Binary Info: MD5 Hash: 9e3b0b3203e71dd8b177bd39effa7bea, Perms: 755, User: carlos
 - Version: 1.0.0-beta.14-dc94a7c
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.6.1)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2023.08.07)
 - Installed scripts: advertising.js; alonemode.js; antiChannelHopping.js; AntiProxy.js; away_mover.js; badnickname.js; bookmark.js; come.js; command.js; CountOnlineUsers.js; Digital_Clock.js; followme.js; Jail.js; norecording.js; rememberChannel.js; sinusbot-commands.js; welcome.js; youtube.js
    linux-vdso.so.1 (0x00007fff98d9e000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f7b2fbff000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f7b2f8a7000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f7b2f4a6000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f7b2eb41000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f7b2e8cd000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7b2e6c9000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7b2e3c5000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7b2e1a8000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7b2de26000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7b2dc0f000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7b2d870000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7b2d656000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7b2d44e000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f7b2fe19000)
 - Time (local): 07.10.2023 17:56:30 CEST +02:00:00
 - Time (remote): 07.10.2023 17:56:30 CEST +02:00:00
 - TeamSpeak3 Version: 3.6.1
 - youtube-dl Version: 2023.08.07
My Problem started when I rebooted my server. I have since then not been able to start my SinusBot Instance which is supposed to connect to a TS3 hosted on the same hardware. However, after increasing the log level, the instance log shows
error while loading shared libraries: liblcms2.so.2: cannot open shared object file: No such file or directory
after which the TS3Client just quits. This was not the only shared object file that was missing, because it seems to just jump from one to the next, after I add one (found some of them online). I also updated my Teamspeak Client version to 3.6.1 (the newest one currently), but no success. Now I'm really stuck and would appreciate some help.
Thanks in advance.
