Sinusbot not responding
Ratkapa16
I've downloaded Sinusbot today for the first time.After installation I started sinusbot in right down corner.It took me to sinusbot page and I started in right up corner the orange button.Then TS3 opened but after 5 seconds it is just shut down...What should I do?
Thanks
Ratkapa16
I'm using WIn10 64bit,8gb of RAM,GTX560Ti,AMD FX8350.
Mozilla Firefox with ad blocker.
Im using beta version(but also tried on stable version).
This is my config.ini
ListenHost = "127.0.0.1"
DataDir = "C:\\SinusBot\\data\\"
ListenPort = 9987
LogLevel = 3
LicenseKey = "O1FOR1MM7JcP/x0nx3l0tIEMQ3cLPiw8QB1iLCMXhBs="
UserAgent = "SinusBot (0.9.13-3609644)"
Are you using the Teamspeak Beta 3.1?
Ratkapa16
Interesting.It works normal until it s starting to connect to any server.Then it crashes and then shows up ts3 crash report.
Ratkapa16
And I figured it out when I remove sinusbot plugin from ts3 plugin folder it works normally.But of course without sinusbot.
Try that, go to your teamspeak sinus bot client, and click in the top bar "help" and then about, which version are you there using?
DuJoCro
Same here, same problem.
I even created a new identity with 24 security lvl and improved it form bot and still doesnt work....
Can you give us more logs? LogLevel 10?
