Solved Sinusbot rootkit?
FrankP
Since last update a week ago rkhunter report following Message:
Warning: Network TCP port 32982 is being used by /opt/sinusbot/sinusbot. Possible rootkit: Solaris Wanuk. Use the 'lsof -i' or 'netstat -an' command to check this.
netstat -anp | fgrep 32982 gives:
tcp 32 0 XXX.XXX.XXX.XXX:32982 104.18.40.220:443 CLOSE_WAIT
XXXX/sinusbot
It seems Sinusbot tryes to contact a me unknown server via HTTPS.
Even if there are no other hints for a rootkit on my server, I am a bit nervous now. Anyone else got this?
Greeting Frank
The autoupdater has changed and contacts new hostnames for that (updatexx.sinusbot.com). When you open 104.18.40.220 in the browser, you see that it's a cloudflare server, which is what we use for that. Update checks run periodically, so you will see those requests frequently.
I don't know where you downloaded the version, but if it's from the official website, you should be fine.
