Solved Sinusbot Scripts does not work
HammerLP
I have rented a kvm-root server on prepaidhoster.de. On this root server i installed a sinusbot, teamspeak and a Minecraft server. But I can‘t install any script with the sinusbot webinterface. And when I install any script over ftp the scripts does not work. The dude in the video had the exact same problem then me.
My System:
Betriebssystem: Debian 10.10
Ressourcen​
Paket: KVM Konfigurierbar (SSD)
vCores: 2 Cores
Prozessor: AMD EPYC Processor, 2.50 GHz
Arbeitsspeicher: 16384 MB
Festplattenspeicher: 50 GB SSD Speicher
Trafficverbrauch: ~12.65 GB von ∞ GB
Netzwerk-Speed: 25 MB/s 25 MB/s
https://youtu.be/2z-th3A2atI
Lala Sabathil
The Webinterface function to download scripts does not work.
You have to put the scripts via FTP or SFTP into the scripts folder and you have to restart the bot.
Lala Sabathil
If just this script doesn't work then this forum category is the wrong one because this is clearly no general bug!
Please submit a bug report in the discussion thread of support++ or join the support++ server on discord.
